Power transformer as Parafeed output? - Page 5 - diyAudio
Old 6th August 2007, 06:46 AM   #41
AJT is offline AJT  Philippines
AJT's Avatar
Originally posted by soundbrigade
What about those 100V line distribution transformers. What can be done with them. Can they be used in as parafeed transformers or similar applications?
do you have them on hand? what are the taps available? is that autotransformer type?
we can determine ratios if can give us the data on those 100 volt line transformers.
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 6th August 2007, 11:47 AM   #42
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Darn, have no data. Have no LC-meter, have no ...
They have separate pri/sec-windings. Measuring DC-resistans give nothing.
They are marked: 100V 8ohm, and have 5 sec taps 0, 10W, 2.5W, 1,25W.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 6th August 2007, 11:56 AM   #43
316a is online now 316a  England
316a's Avatar
Why bother when a toroid will have better performance ? Those 70/100V transformers don't usually have enough inductance to give any sort of decent bass . In fact why parafeed at all ? A toroid can be used SE if there is a tertiary winding to offset the core DC , then the parafeed cap and anode load choke (or CCS) are redundant . Below is a schematic of a recent amp which used a 30VA 230:9+9 toroid where one of the secondaries is used to (nearly) 100% offset the anode current . -3dB points at 15Hz and 47khz with a 280mH choke (not 30mH as in the schematic) . Finding suitable offset chokes is the main problem , although if there is enough compliance I'm sure a CCS could be used
cheers
316A
Old 6th August 2007, 12:02 PM   #44
316a's Avatar
Originally posted by Shoog
So your conclusion is that smaller (to a point) would be better.
Shoog
Smaller units have higher turns per volt and hence more inductance . 30VA came out slightly better than a 50VA unit in my case . The smaller 15VA toroids , which also had potted cores measured worse .
cheers
316a
Old 6th August 2007, 12:24 PM   #45
Hi Magnus,
100V line, 10W, 8ohm is around 1 kohm primary (winding ratio ca 11:1).
It is about time you make something out of those 12B4s, maybe by parallelling a few and parafeed them into the line formers!
See you again at "hifi-forum"!
Old 6th August 2007, 01:56 PM   #46
Thanks Lars. See you!
/Magnus
Old 6th August 2007, 01:59 PM   #47
AJT's Avatar
okey, so at tap 1.25W and 8ohms, we have a transformer good for 3.5k to 8ohms....
Old 6th August 2007, 02:17 PM   #48
I may consider use the transformers for a headphone amp I need no power at all ... hardly.
/Magnus
Old 6th August 2007, 02:20 PM   #49
Nope,
In my calculations the winding-ratio is 31,6:1 which corresponds to 8k:8ohm impedance-ratio.
Old 6th August 2007, 02:21 PM   #50
AJT's Avatar
yes i believe so, the primary will never see 100volts so response should be okey...
Output transformer current and power ratings boywonder Tubes / Valves 3 29th April 2009 10:00 PM
2A3 SE parafeed with PP-transformer revintage Tubes / Valves 66 28th October 2008 10:47 AM
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 03:57 PM
Parafeed output croccodillo Tubes / Valves 0 17th January 2007 03:51 PM
High Power - Output transformer h_andree Chip Amps 8 2nd March 2004 06:45 PM
Copyright 1999-2017 diyAudio
