Difference between microphones
Old 18th May 2006, 06:40 PM   #1
Mike150 is offline Mike150  Austria
Default Difference between microphones
Hi everybody!
Thatīa very important question, so please help me....
Whatīs the big difference between condenser and tube microphones?
I hope thatīs the right forum.
Thx
Mike
Old 19th May 2006, 01:33 AM   #2
jon_010101 is offline jon_010101  United States
Generally, a tube microphone is a condenser microphone that uses a tube (often a 12AX7 or similar) for gain and to help drive the mic cable. Condenser mics that don't use tubes have a FET or op-amp to do the same task. The catch (cost aside) is that tube condenser mics require a dedicated external power supply, while solid state condenser mics can run off standard 48V "phantom power" provided by the mic preamp.
Difference between microphonesHide this!Advertise here!
Measurement microphones ShinOBIWAN Multi-Way 18 5th January 2006 10:27 AM
SPL microphones? thylantyr Multi-Way 3 18th June 2005 07:19 PM
Please Help My Tube Microphones! northsiderap Tubes / Valves 4 6th May 2005 04:53 AM
Cheap microphones? pentium Everything Else 0 30th October 2003 03:50 PM
Copyright ©1999-2017 diyAudio
