| diyAudio Sponsor | ||
I have some of Bas’s Aikido PCBs, to feed a horn system I’m assembling that will have a max dB of about 117 dB.
(I was going to use an autotransformer volume control www.intactaudio.com/atten_FAQ.html, but they don’t provide enough attenuation. So I’ll use a stepped attenuator, for which attenuation is still less than an ordinary pot . . ) So: I want to build an Aikido pre, that other things being equal has the *minimum amount of gain. Gain = Half the first tube What really good sounding tube has the *minimum amount of gain? Thanks Richard |
#2 |
rick57,
Goto and look at the last page... Aikido tubes: results and values http://www.tubecad.com/2006/05/blog0064.htm Alain.
#3 |
Thanks Alain!
Is there anything between the 6AS7 and 12B4 in sound quality/ price/ availability? Cheers |
#4 |
diyAudio Moderator Emeritus
Hi Richard,
Unless you use wires from the 12b4 sockets to the board. The 12B4 cannot be accomodated. Also not in JB's boards because it is not a double triode. The 6AS7 can be used in the octal boards. Regards, Bas |
#5 |
Hi Bas,
Thanks for your info ~ How is the 6AS7 compared to similar Output Gain: 6BX7/ 6GM8/ 6H30? Regards, Richard |
#6 |
6AS7 and 6BX7 are both octals
the 6GM8 and 6H30 are nine pin tubes the "first tube" in the aikido really determines the gain. The second one is a cathode follower and all have slightly less than a gain of 1 (except for the 6AS7 which is bit lower). So BALLPARK figures 6AS7=2 6BX7=5 6GM8=7 6H30=8 So the answer would be. IF 9 pin THEN 6H30 OR 6GM8 END IF I don't know how available the 6GM8 is though. IF octal THEN 6BX7 OR 6AS7 END IF Since the 6AS7 has a hefty filament current I would go for the 6BX7 but..YMMV But if you really want MINIMAL gain..use the 6AS7 in first position and maybe something with less current hungry filamant as cathode follower...you would be using an insane amount of heater filament current for a preamp if you would use 4 6AS7's. |
#7 |
Hi Bas
Can you remind us memory challenged - Are the boards any more suited to octals or 9 pin tubes Cheers |
#8 |
Hi Rick
I gave a look at your link and found this question and answer Q - what if I need more than 42db of attenuation. A - Custom units can be wound to 54dB of attenuation. Note that that is a 500:1 stepdown and may compromise the performance slightly. If you require that much attenuation you might want to examine the gain structure of your system. Isn't there a possibility in your system to reduce gain? Erik |
#9 |
Hi Erik
> Isn't there a possibility in your system to reduce gain? Unfortunately no, the power amp is only 2 watts (a 45 SE). My central question is: Is there anything between the lowest mu tubes, eg 6BX7/ 6GM8/ 6H30? in sound quality/ price/ availability? Rick |
#10 |
If one is trying this hard to limit the gain in an Aikido stage, why not just try a well-implemented cathode follower with current source loading? A 12B4A would be a good candidate.
| Lowering Gain on an Aikido Preamp | SRMcGee | Tubes / Valves | 12 | 11th March 2007 08:49 PM |
| Low gain 9-pin tubes for Aikido? | gurevise | Tubes / Valves | 8 | 2nd January 2007 11:51 PM |
| minimum gain for LM1875 | Leolabs | Chip Amps | 3 | 14th November 2006 01:53 AM |
| Hybrid Aikido-ish gain stage | Fuling | Tubes / Valves | 3 | 5th September 2006 09:49 AM |
| Minimum gain for 2020? | Nuuk | Class D | 7 | 16th November 2005 03:24 PM |
| Page generated in 0.08952 seconds (86.28% PHP - 13.72% MySQL) with 10 queries |
