ECL 82 low power end tube - diyAudio
Old 24th November 2002, 09:12 PM   #1
Question ECL 82 low power end tube
Hi everybody,
I want to ask: does anyone know something about the ECL 82 tube? Since a few months I have bought the 'Klein&Hummel Telewatt VS-56' and it sounds very nice, but the output power is on the lower side. Perhaps a matching speaker?
Maarten.
Old 24th November 2002, 09:40 PM   #2
Fuling is offline Fuling  Sweden
Gday
ECL 82 is a nice little tube with one input triode and one output pentode in the same "bulb". Maximum plate dissipation for the pentode is about 7 watts if i remember correctly.
Nice tube to build simple amps with, as one tube (per channel)contains "everything" needed for a single ended amp. Puts out somewhere around 3 watts in SE pentode mode.
My first tubeamp employed two PCL 82s (same thing but different filament voltage) with the pentodes wired as triodes.
Quite sweet little bugger...
Old 24th November 2002, 09:49 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Default K&H
You would need speakers in the 94 dB/Watt range at 8 Ohm at least to get some decent output on these.
What exectly would you like to know about the ECL82/6BM8?
Ciao,
Frank
Old 24th November 2002, 10:20 PM   #4
fdegrove's Avatar
Default APPLICATION NOTES
I came across it accidentally so why not:
ECL82/6BM8
Good news for you is that this valve is still in production and relatively cheap.
P.S.:
K&H
Frank
Old 24th November 2002, 10:40 PM   #5
frugal-phile(tm)
planet10's Avatar
Default Re: APPLICATION NOTES
The 6BM8 is a nice little tube -- it has quite a following, particularily in Japan. I am using an SEP 6BM8 in the lab (Calrad) and it does a not bad job of driving my little alnico BK101 hons (90 dB). I also have a couple more that came out of Roberts R-R tape decks. One of these days i'll go over one of them properly and see what i can squeeeze out of them sound-wise.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th November 2002, 12:01 AM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
I might try the russian variant 6F3P sometime.
I wish they had a 60v heater though; then you could make a two tube transformerless (less the OPTs) stereo amp..
some kind of little deal..
use input trannies to isolate it.
Old 25th November 2002, 12:05 AM   #7
fdegrove's Avatar
Default 60V HEATER?
Why would you need that for and what has it got to do with OTL?
Are you talking heater to cathode insulation voltages?
Puzzled,
Frank
Old 25th November 2002, 12:14 AM   #8
Colt 45:
Try to get some UCL82s . They have 50V filaments. A bit hard to obtain maybe, but should be possible
Old 25th November 2002, 12:21 AM   #9
fdegrove's Avatar
Default UCL82
Why not just polarize the upper tube with a part of the anode supply so that you don't exceed heater to cathode insulation ratings?
I see your point but having a 50V heater supply isn't the sollution since these are current driven heaters.
Ciao,
Frank
Old 25th November 2002, 12:22 AM   #10
Tom Bavis's Avatar
Default UCL82
Or maybe not so hard to obtain - 50BM8: $4.00 each at http://www.vacuumtubesinc.com and
http://www.vacuumtubes.com
could 24A been power tube sam8888ysl Tubes / Valves 29 14th December 2016 02:05 AM
tube-like SS power amp rtill Solid State 47 13th April 2009 01:06 PM
any way to fix a end cap on a 807 power tube karma Tubes / Valves 9 9th September 2005 03:39 AM
tube/SS hybrid (low power)- need tube help trespasser_guy Tubes / Valves 26 6th July 2003 08:15 PM
Copyright 1999-2017 diyAudio
