diyAudio Sponsor
Old 15th May 2006, 04:54 PM   #1
guitvinny's Avatar
Default 6L6 Push pull -- Power tranny question
Take a look at this amp : http://www.geocities.com/mydesign_99/PP6L6.JPG
- Does it realy going to draw 200 mA over the power transformer ? Cause I would like to use a edcor transformer for 2 channels of this amp... and I think a 500 mA is a biiiit overpower.
Old 15th May 2006, 06:49 PM   #2
Yes.
Since the diff stage already has a negative supply for its ccs bias, why not use the same supply for the 6L6 bias and not use R11 and C3?
Old 15th May 2006, 10:56 PM   #3
Hi quitvinny ,
Except for the input stage , the output schematic PP 6L6 Class A
is a classic , and it REALLY DRAWS about 170 - 200 mA at the full
power . and for two channels , you will really need about 400 -
450 mA of useful current .
The total output power is 18 Wats of pure Class A per channel .
But the sound is very amazing , very smooth and I'm sure that you will like it .
Carlos
Old 16th May 2006, 01:08 PM   #4
guitvinny's Avatar
Ok, I`ll check with edcor if 1x450 mA or 2x250 mA is less costy. For the output tranny, who can I calculate the primary impedance ? Is 7600 ohms will be allright like the CXPP25-8-7.6K ?
Old 16th May 2006, 01:40 PM   #5
guitvinny's Avatar
For the output tranny, I check on http://tdsl.duncanamps.com/show.php?des=6L6
Zout is the impedance right ? do I look in the good column : Class : A PP Va : 270 .....Zout 5000 ??
Old 16th May 2006, 02:22 PM   #6
mod_evil's Avatar
Send a message via MSN to mod_evil
Can I use a 6sn7 in the place of 12AT7?
What is the sound of this amp?
Brazilian Tube Amp Builder.
Old 17th May 2006, 01:19 AM   #7
Hi quitvinny ,
As I said , this 6L6 PP Class A schematic is a classic and the correct Zout , that is the total load ( plate to plate ) is 5000 ohms , and the +B correct value is
270 – 300 Volts . Use a output tranny that can “hand” 25 Watts or more .
Preferably use a matched pair or a same brand / same lot pair of 6L6’s in each channel , because the quiescent current is high ( about 170 mA total or aprox. 85 mA per tube ) and if the current through one tube is very diferent from the current through another tube , this fact will cause a lot of distortion at the output.
( don’t forget : the output tubes are cathode coupled by the 125 ohms resistor )
Don’t try to change the cathode resistor , the correct value is on the schematic
( 125 ohms ) , and this value will give an aprox. grid bias value of ( - ) 20 Volts .
Don’t worry about the high value of quiescent current , because the tubes are
connected in the push-pull way , and the magnetic field created by one tube is
entirely canceled by the opposite magnetic field created by another tube .
The circuit is highly stable , and you won’t have any kind of trouble .
Good luck ,
Carlos
Old 17th May 2006, 01:37 AM   #8
Hi mod_evil
No you can’t use the 6SN7 in the place of 12AT7 in anyway , they are totally
different . The 6SN7 is a medium mu and the 12AT7 is a high mu dual triode .
The 6SN7 Class A grid bias is ( - ) 8 Volts and the 12AT7 Class A grid bias is
( - ) 2 Volts at 250 Volts plate voltage , the plate resistance and transconductan-
ce are different too .
If you follow the above gave schematics , will result a very amazing and a very
smooth sound .
Carlos
Old 17th May 2006, 05:15 AM   #9
diyAudio Moderator Emeritus
ray_moth's Avatar
The reason the 12AT7 was chosen for the first stage, I suspect, was that it can draw enough current to drive the LM317 and also has reasonably high gain. A 12AX7 has more gain but would draw too little current. 12AU7 (or 6SN7) would be the opposite.
If I were you, I would not use the LM317 as a CCS - it's reputed to have a poor high frequency response. Choose a better CCS, maybe using a couple of transistors of appropriate type. If you do that, it would also allow you to use a higher gain but lower current tube for the first stage, such as a 12AX7 or, better still for sound quality, a 6SL7.
If you want to make it sound even nicer, use a choke in place of the 100 ohm resistor (R12) in the power supply, especially if you're planning a common supply for both channels.
Old 17th May 2006, 02:06 PM   #10
guitvinny's Avatar
Hey, thank you all,
For CCS, where can I find good desing information ? or if you have shematic lying around send it to me.
And if I do that, can ou tell me ray_moth what I will have to change to use 6SL7 ?
Last question : I saw silver-steel bar on ebay (dia : 1 mm) does anyone have ever work with this material ? I would like to use it as a bus bar.
Push-Pull question roomi Power Supplies 5 26th December 2008 10:53 PM
push pull power amp design question (a lot of actually :) ) krusty75 Tubes / Valves 6 25th September 2008 05:07 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Power rating for push pull configuration question miked15 Tubes / Valves 4 15th May 2002 02:50 AM
Page generated in 0.10647 seconds (83.23% PHP - 16.77% MySQL) with 11 queries
