Transformer problem
Transformer problem
Old 15th May 2006, 08:09 PM   #11
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Transformer problem
Maybe there is not anough DC voltage to supply regulator ? Too low filter caps ? What regulator do you use ?
Old 15th May 2006, 09:33 PM   #12
trombone is offline trombone  United States
It's been working for years, with some intermittent failures--the case as I write. I'm pretty convinced at this point that the problem is mechanical. As someone pointed out, something is drawing current, and given some history, it has to be in the cable I built for it. Anyway, it's an LT1085, I think.
Trombone
Transformer problemHide this!Advertise here!
Transformer problem... 5150ed Chip Amps 19 28th June 2008 02:25 PM
EI transformer in case problem jaycee Solid State 10 1st May 2007 03:43 PM
Serious transformer problem Nixie Power Supplies 50 20th October 2006 11:27 PM
Transformer problem Semir Power Supplies 3 2nd January 2005 11:36 PM
Transformer problem deepanger Solid State 18 5th February 2003 05:48 PM
Copyright ©1999-2017 diyAudio
