Doubts on cathode stripping in tubes
Old 19th January 2016, 04:43 AM   #41
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Indirectly, this the rationale for using hydrogen/deuterium as fill gas in HV, high power thyratrons. The lower mass/charge ion has less of a tendency to blow hell out of the large area, high emissivity cathode surfaces needed for a good high power thyratron. Xenon, neon, and mercury fills are used for lower operating voltages.
Old 19th January 2016, 06:31 AM   #42
cerrem is offline cerrem  United States
cerrem's Avatar
There are cases of cathode stripping during start-up of receiving tubes where the Heaters are "floating" on a DC voltage derived from the B+...
The damage occurs due to the Heater to Cathode voltage is greatly exceed for a short time before the B+ pulls down to it's loaded state.... Very repeatable....you can hear the clicking sound of the arc..
Simple fix is to put a protection zener on the voltage divider ...this way the zener clamps only during start-up, preventing an over-voltage on the Heater...
Problem 100% solved ...
Old 19th January 2016, 08:47 AM   #43
Guido Tent is offline Guido Tent  Netherlands
Originally Posted by Bandersnatch View Post
If that were the case, no IDH rectifier would survive turn-on.
cheers,
Douglas
of course I am talking long term use, incidental cases do not harm
Guido Tent
www.Tentlabs.com
Old 8th April 2016, 08:02 PM   #44
Uunderhill is offline Uunderhill  Canada
To point out, here is an article called Kindness to Filaments by John Harper.
http://www.john-a-harper.com/FilamentHeating/index.html
To be kind to the heaters, he suggests doubling the heater supply voltage,
but a resistor is connected in series with the heaters.
The value of the series resistor is the same as a warmer up heater.
Last edited by Uunderhill; 8th April 2016 at 08:28 PM. Reason: technical correction
Old 9th April 2016, 10:24 AM   #45
DF96 is offline DF96  England
Normal AC heater supply is sufficiently kind for most purposes, as the transformer resistance limits surge current.
Doubts on cathode stripping in tubesHide this!Advertise here!
Cathode stripping in low voltage tubes engels Tubes / Valves 1 26th March 2008 05:05 PM
Doubts regarding a 1Watt FM TX Kit xitronics Solid State 8 23rd May 2007 09:19 PM
Why don't we use output tubes as cathode followers? dsavitsk Tubes / Valves 15 29th January 2007 06:32 AM
VR Tubes as Cathode Bias of 2A3 SRPP Loftin-White snoopyma Tubes / Valves 8 16th June 2006 05:00 AM
Resistors & doubts ;( Duck-Twacy Pass Labs 11 15th May 2003 08:55 AM
