| diyAudio Sponsor | ||
Just thinking about future projects,I found this http://digilander.libero.it/essentia...fier_+sche.htm
and it looks nice,but does anyone have a schema with usual transistors,not mos trasnsistors??
Regards Åke |
#3 |
Nice! How much heat does it make,what heatsinks to use?
And a trafo 2x35v how big for 1 chanel?
Regards Åke |
#4 |
2x50v DC isn´t it a little to high for class A at 30w?Just thinking.
If I where to try this one with regular transistors,e.x MJE 21193/94 or MJ15003/04 are there any changes needed to be made?
Regards Åke |
#5 | |
sorry, Jim |
#6 |
Been thinking about this http://www.geocities.com/Tokyo/5913/6922.html
will it work with such a high voltage on rails in class A? Or if i lower them a bit maybee +- 35v?
Regards Åke |
#7 |
The tubes used in this amp http://www.wdehaan.demon.nl/hybrid/6463hyb/index.html
5687,7044 or 6463 do they have any equalents like 12AT7 or..?
Regards Åke |
#8 |
i recently built a hybrid amplifier useing 6922 front end.. there is a thread in this section and over in the solid state section about it..
Owen |
#9 |
Here is what I did, idle current is 500 mA, be sure to use multiturn potentiometers.
Oh didn't see you wanted bjt's instead of fets, why would you want that? |
#10 |
this is what i did.... it still needs a bit of refineing and could probably do with haveing another SS stage added makeing it into a tripple darlington but it is all explained HERE I suggest you have a good read of that.. this is the circuit as it stands now and it is working on the bench, i have yet to refine it and build a final version as i got distracted by a chipamp... but it is a good start...
| Chearch schema DBX 386 | studervox | Parts | 0 | 14th April 2008 03:06 PM |
| 6P15P hybrid amp schema? | L30N^_^H34RT | Tubes / Valves | 16 | 19th January 2008 05:20 PM |
| My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. | Spasticteapot | Multi-Way | 0 | 30th November 2006 04:16 AM |
| Mc 275 CE schema | spoke | Tubes / Valves | 5 | 29th October 2005 12:35 PM |
| Schema NAD 310 | fantomas | Solid State | 4 | 13th September 2005 05:50 AM |
| Page generated in 0.11197 seconds (74.96% PHP - 25.04% MySQL) with 11 queries |
