| diyAudio Sponsor | ||
I've 3 power transformer from Tektronix 545 oscilloscopes. I figured out the specs for the heater winding (by means of the handbook/service manual). But I have no clue for the high voltage current ratings. Does any of you have any info on these trannies ? There are 100+ tubes in this scope so I think they are pretty beefy. Thanks, Jim |
#2 |
??? you have the specs there! what is the question?
Jesus loves you. |
#3 |
The current ratings of the HV-windings ???
Jim |
#4 |
Doesn't the schematic show the load on each? I recall that each winding had 10 Ohm power resistors which were used as current test points.
If not, you can measure the DC resistance and allow 2W dissipation for each. So a 10 Ohm winding can handle 450 mA (.45^2 * 10 = 2.02W). Maybe a little more if some windings are left unloaded. Naturally you can series connect windings for the voltage you want - Tektronix did. A stereo 6550 amp would be no problem with one of these... |
#5 |
I've also got a few salvaged Tek scope transformers, sitting on a shelf awaiting a new call to service. I don't know that this will help you a whole lot, but I've attached the schematic for the 545 supply if you don't have it already. You can get at least some idea of each winding's prowess by looking at the regulator that goes with each one.
Tek 545 power supply
Brian |
#6 | ||
I'm going to measure the windings and calculate, then compare these findings with the schematic. Thanks, Jim |
#7 |
Those old Tek trannies are great for projecs,and experimenting.I've got a couple here..Loads of windings to play with!
Humm.. 545 huh? Whats the number on the tranny? (120-xxx or something?) *digs around* Dean Kidd: dektyr(at)teleport(dot)com or Stan: w7ni(at)easystreet(dot)com Can probably help you out,they've helped me find specs for Tek trannies before. Another good place to check would be: http://groups.yahoo.com/group/TekScopes/ |
#8 |
#9 | |
Jim |
#10 |
And here's the power supply schematic to the Tek 531/541. It is very similar to the 545 power supply I posted above. Which means that if we can believe the Fair Radio ratings provided for the 531 transfomer, the 545 rating ought to be close to the same. Note also that in the 531/541 schematic, voltage drops across the 10 ohm resistors are given.
Brian |
| Tektronix 100Mhz Digital Oscope CHEAP | bbksv | Swap Meet | 0 | 9th March 2007 11:23 PM |
| Oscope Dumont 190 | infinia | Parts | 3 | 9th March 2006 09:45 PM |
| Oscope testing | A3rd.Zero | Equipment & Tools | 3 | 27th April 2004 10:36 AM |
| Free OScope! Spring cleanup | jackinnj | Swap Meet | 0 | 26th February 2004 02:39 PM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| Page generated in 0.10626 seconds (78.91% PHP - 21.09% MySQL) with 11 queries |
