Old 10th May 2006, 05:39 AM   #21
lndm is offline lndm  Australia
My experience is single ended. I guess the real issue is less of the cathode voltage and more of Vg-k.
Old 10th May 2006, 06:18 AM   #22
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Oh I see, but thank you for the great post. I'll checkout my single ended amps
Old 10th May 2006, 11:28 AM   #23
SY's Avatar
Originally posted by arnoldc
Indm, can I use just a scope and signal generator to see my amplifier's overload recovery capability or lack of? If so, may I ask how?
Better to use a soundcard instead of the generator. Find a copy of Dazyweb Labs' SG-2102 signal generator software. You can set it up to play a sine wave at arbitrary alternating levels with arbitrary repetition rate. To look at overload, I'll set the higher level to something that will take the amp well past clipping, then the lowerr level at something just below clipping. Varying the rep rate will let you see if the amp instantaneously recovers by watching the lower level.
It takes a bit of squinting and playing with the scope sweep to hit a point where this is easy to see, but trust me, it will only take you a few minutes to find appropriate settings of the scope and software.
If there's a sucker born every minute, where do the rest of them come from?
Old 10th May 2006, 11:56 AM   #24
http://speech.di.uoa.gr/dsp/program/...rator_2102.zip
Old 10th May 2006, 11:46 PM   #25
SY, my problem is that my Acer notebook with RealTek Audio is really crappy and can't even generate a decent square wave with a previous software I tried
Indm, thanks for the file!
Cheers!
Old 11th May 2006, 01:03 PM   #26
Originally posted by Johan Potgieter
they must be PNPs.
I'm not sure I understand the difference between these two versions. I found that for a nominal output (about 3Vp-p), the signal at the cathode was about 3mVp-p in both cases.
Old 11th May 2006, 01:06 PM   #27
SY's Avatar
That may be, but for this app, you want sine waves, which sound cards do much better. Getting a good square wave out of a sound card, even an excellent sound card, is pretty much impossible.
Old 11th May 2006, 07:17 PM   #28
Indm,
Righteo... I stand corrected; a little quick on the trigger. One can obviously regard any active or power zener as a cell on its own for either polarity - your 2 circuits are the same. I am afraid I was blinkered to my own circuit and perhaps the nicety of a collector directly on the chassis. The 300mV you measured should surely come as close to fixed bias as one would wish for.
I will post my own circuit just for the record as soon as my @%$*# scanner will work again; as said it is pretty standard.
Old 12th May 2006, 12:11 AM   #29
Thanks Johan.
Parts recovery from PCs? TDWesty Chip Amps 3 10th January 2007 05:30 PM
OT Overload question alexmoose Tubes / Valves 1 9th May 2006 12:56 AM
Damage recovery Reklats Chip Amps 1 31st March 2005 02:42 AM
jvc amplifier overload TaylorG Solid State 19 10th January 2004 11:17 PM
Copyright ©1999-2013 diyAudio
