diyAudio Sponsor
Old 7th May 2006, 11:47 AM   #21
Merlinb is offline Merlinb  United Kingdom
Also, long tailed pair phase inverters are liably to oscillate if you feed them with too low frequencies. C12 is there as a quick fix to stop this, but for a proper design I would reduce the value of C11 to 4n7 for a roll-off of 17Hz.
Old 7th May 2006, 04:30 PM   #22
merkur is offline merkur  Canada
For the grid stop of the output, I had try bigger resistor like 10 K with no result justifing them.
I will try with lower capacitor in C11 and I 'll get back with the result
Thank's
Old 7th May 2006, 04:41 PM   #23
SY's Avatar
One more thought- you might be having a negative resistance condition in the screens as you push it hard and the supplies sag. That could cause an oscillation burst. I haven't experienced this myself, but I've sure heard about it.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 7th May 2006, 05:04 PM   #24
Doesn't that only apply to tetrodes?
Old 7th May 2006, 05:25 PM   #25
SY's Avatar
You can see those kinks in some pentode/beam power curves.
Old 7th May 2006, 10:39 PM   #26
How much in (%) ripple is acceptable on the plate and on the screen voltage supply when the amplifier is driving at maximum?
I'm not sure about the voltage doubler. Does it need more capacitor?
The oscillation seem to have stop but now i'm hearing like a gost note
especially when i'm playing up the neck on the guitar only when i'm driving the amp at maximum.
Any hint?
Old 7th May 2006, 10:51 PM   #27
SY's Avatar
I'm ignorant of what guitar guys do in that respect. It might be worth poking through the tech notes at Aiken Amplification to get a better feel for it.
Old 7th May 2006, 10:58 PM   #28
By sure that I already whent trought all aiken have put on his web site.
Old 10th May 2006, 01:19 AM   #29
Thank you guy's for all the information but my problem was that the driver was clipping before the maximum preamp signal. Now I have change that and the oscillation disapear. But now I see 120hz in my signal and I know that it come from my supply so any advice on my voltage doubler, publish earlier, will be welcome.
807 AB2 oscillation maybe? Craig405 Tubes / Valves 27 25th March 2008 10:01 PM
CDP Oscillation emmasdad Digital Source 0 4th January 2006 03:54 PM
Oscillation raveenvijendren Solid State 15 18th December 2005 11:16 AM
oscillation?? wintermute Solid State 8 13th July 2005 01:45 PM
Oscillation udip Solid State 5 31st January 2005 06:43 PM
Page generated in 0.10312 seconds (75.16% PHP - 24.84% MySQL) with 11 queries
