diyAudio Sponsor
Old 4th May 2006, 12:56 AM   #1
dsavitsk's Avatar
Question Determining Output Power
How do I determine the power that a given tube with a given transformer, a given B+, into a given load is capable if delivering?
I ask because I hooked up a 6gm8 to some edcor transformers (5K:8) and was surprised to find that it did a pretty good job on my Grados. Gain was a little low, but bass was great and sound was surprisingly good. I am curious what was going on, and how to improve things.
Old 4th May 2006, 01:17 AM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I normally do it actual measurement- using a Simpson Power Level meter.
Old 4th May 2006, 04:09 PM   #3
Default estimated
It can be estimated using lots of assumptions. Some folks will plot the loadline and determine graphically the power out. Plotting a loadline requires info such as B+ and load impedance. Results are power out of the power tube to the load (transformer). Power to the speaker is reduced by transformer loss (estimated).
Old 4th May 2006, 04:37 PM   #4
dsavitsk's Avatar
I know how to plot load lines, and I am happy with a very rough estimate. So, how do you do it? I found one person saying to muliply change in current by change in voltage and then multiply the whole thing by 8, or divide it by 8, I don't remember. Something like that
As I say, I got a surprising amount of power from a 6gm8, but I'd like to see if it is as surprising as it seems, and how various other tubes might compare so I have a sense what to tinker with. So, even knowing how one tube relates to another, that is, estimating proportional power, would be fine.
Old 4th May 2006, 05:36 PM   #5
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
I would tell you to look at the Radiotron at my site, but for a quicker answer, I suggest you to dig into the articles about loadlines here:
http://members.aol.com/sbench102/po-dis.html
Old 4th May 2006, 07:17 PM   #6
cerrem is offline cerrem  United States
If you can provide some more detail... I will show an example of first order calculation...
The details of the circuit are important....
Chris
Old 4th May 2006, 09:03 PM   #7
rdf is offline rdf  Canada
rdf's Avatar
Remember though headphones are relatively high impedance devices that respond to voltage, not current. Grado rates their efficiency in milliwatts/per severity of tinitus. One watt into Grados is called fireworks.
Ears aren't microphones.
Old 4th May 2006, 09:23 PM   #8
dsavitsk's Avatar
That's excellent. Thanks.
It is just a transformer with one side connected to the plate and the other to B+, and a resistor and cap from the cathode to ground.
That's true for sennheisers and other high impedence phones, but Grados (at 32 ohms) are all about current.
Now that probably is true.
Old 4th May 2006, 09:43 PM   #9
Miles Prower's Avatar
It's NBD, actually. Here's a loadline I did for a SE 6BQ6GTB project I'm working on. Given the Pd of this tube (12W) it looks like Vpkq= 250Vdc is a good place to start. For this voltage, assume that the Vpp`= 500Vdc, since the xfmr primary represents a "phantom" Vpp rail. The primary inductance does this. Once you have that voltage determined, it's simply a matter of fishing for a loadline that gives the best linearity without busting the Pd spec. For this, I print the plate curves out to make it easier to play with them. In this case, the THD= 0.3%. Of course, this is just an estimate since the equation used assumes that the second harmonic is the only component present. That never occurs in the real world, but it is a useful estimate. Once you have that loadline determined, simply read off the maximum and minimum voltages to figure power out: Po= [(Vpmax - Vpmin)/(Ipmax - Ipmin)]/8.0. The divide by eight turns P-P values into RMS values.
Of course, once you start to build the thing, you will probably have to tweak the op-point somewhat to realize the best distortion performance. Fortunately, VTs tend to be quite forgiving concerning op-points, moreso than SS.
For more details, see Steve Bench's Site. There are five articles on loadlines under the "Technical Reports" heading.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 4th May 2006, 10:24 PM   #10
rdf's Avatar
In the world of headphones 32 ohms eats power, in the world of OPTs meant for speakers it's nothing. I've run headphones directly off the output of devices ranging from a single stage 6C45 5-kohm SE to a Crown D-75 (deaf sportscaster.) Power really isn't important until your start paralleling.
Determining ratings for unknown Power Transformers boywonder Tubes / Valves 3 22nd April 2009 10:27 PM
Determining max power handling putergod Multi-Way 4 1st December 2007 06:40 PM
determining power consumed by the amp circuit shotcoach Chip Amps 2 10th March 2007 10:40 PM
Thumb Rule for determining Approx output power of class AB amp rajeev luthra Solid State 12 3rd August 2004 07:34 PM
determining power handling of a speaker GeniX Multi-Way 3 14th October 2002 03:40 AM
Page generated in 0.12190 seconds (81.56% PHP - 18.44% MySQL) with 10 queries
