| diyAudio Sponsor | ||
I am planning to change the power supply for an old tube amp (4xEL34), becuse it is way too heavy. The core of the transformere is for about 650W, so I would like to change it for something smaller.
I was thnking about step-up converter, but am not sure if it is the right way, becuase then there would be 500V non-isolated from Ground. Is there any simple SMPS design without a transformer, which I would just build and leave, without any testing or setting? And just by the way, will the SMPS bring much more noise to the circuit than the transformer? |
#2 |
You would still need to use a transformer for isolation....but it would be relativley tiny compared to what you were using...
SMPS for audio is easy and very do-able... There are plenty of folks against SMPS for audio applications mostly due to ignorance...they still think in terms of 1970's -1980's switching technologies...This is because most of the books out there on SMPS, were written back then...as with the Unitrode stuff.... The big argument is mostlly over EMI issue... This can be simply avoided by using a quasi-resonant converter... For your application your best bet is a Push-Pull converter in current mode...Quasi-Resonant... Switching no less than 500kHz..with a cross over frequency around 80kHz to 100kHz... Chris |
#3 |
could you post some schematic? I donīt know how a quasi-resonant smps looks like.
I know I need an output transformer for tube amp, but do I need a supply with transformer? I thought I could use an off-line converter only with inductance, but as I think about it it sound kinda dangerous.. |
#4 |
It is dangerous. This is the sort of project to undertake only after very much study.
Jesus loves you. |
#5 |
Try searching the forums too. We beat this horse a few times
#6 |
Well, I changed my mind, I donīt want to get electrocuted because of my own mistake.
Is it possible to create converter from 12 to around 500V, without a transformer? Does anyone have some good link to a guide how to make a mains transformer or HF trafo for SMPS? |
#7 | |
http://schmidt-walter.fbe.fh-darmsta..._e/smps_e.html |
#8 |
That was fast, THX!
Do you think that simple boost converter is good enough for my start with tubes? I mean the noise and such like. It will be supplied from a PC supply, what about that? BTW what is EMI? |
#9 |
EMI = Electo Magnetic Interference and is the plague of SMPS + hi-Z input devices, tubes or FET's.
I did a small (55W) one for auto use. The final schema and thread of R&D is here: http://geek.scorpiorising.ca/GeeK_Zo...14416#msg14416 Shielding and feedthrough caps for the power leads are a must. I didn't try a transformerless boost convertor yet. Plan to in the future when I want to be brave and try SS again |
#10 |
I seem to recall so many cases of members unsuccessfully attempting SMPSs without a magnetic element that it has almost acquired an aura of impossibilty without a full-on research and design facility.
Jesus loves you. |
| HV SMPS for tube preamp | Johan_Ch | Power Supplies | 8 | 6th December 2010 04:31 PM |
| FS : Battery Supply Tube Preamplifier (12V SMPS to 275V) | ANALOG GUY | Swap Meet | 0 | 30th October 2006 08:38 AM |
| SMPS & tube pre-amp development board. | ianl | Tubes / Valves | 2 | 10th April 2006 06:05 PM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.10357 seconds (75.22% PHP - 24.78% MySQL) with 11 queries |
