DIY Hybrid poweramp noise and hum problem
Old 30th April 2006, 09:28 PM   #1
maxpou is offline maxpou  Canada
maxpou's Avatar
Unhappy DIY Hybrid poweramp noise and hum problem
Hi everyone,
i have diy hybrid power amp no feedback with tube 6922 input circuit SRPP and 6 output mosfets IRF130, 9130 class ab. My power supply for output stage 1 transfo by each channel and 20000uf by rail. PS for tube is regulated by this circuit (see this adress)
http://www.diyaudio.com/forums/showt...threadid=78629
i have a noise and hum how i place my GND? thank you!!!
Old 30th April 2006, 10:10 PM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Can you show us an pictures how you have it connected now and have it running. ? what about a full schematic ?
Old 2nd May 2006, 01:21 AM   #3
maxpou's Avatar
Hi Jleaman, thank's for your answer.
here the schematic of my poweramp.
description of wiring gnd:
1- input rca gnd is on resistor input to gnd
2- all gnd of tube circuit is on my transfo CT
3- low voltage gnd is on transfo CT and there is a aluminium jumper which connect each channel and ground tube circuit.
thank you!!!
Old 2nd May 2006, 07:06 AM   #4
Banned
Is this all on a bread board or is it on a circuit board ?
Old 3rd May 2006, 12:36 AM   #5
maxpou's Avatar
Hi Jleaman,
i have three boards, one for my power supply, one by channel with small circuit bias for mosfet. i don't have a board for my big cap because it's a cap with screw. thank you!!!
Old 7th May 2006, 05:37 PM   #6
maxpou's Avatar
somebody can help me to find my hum and noise problem? thank you! Maxpou
Old 7th May 2006, 05:53 PM   #7
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
You don´t have a schema with all the components values on,and any data on the amp?
Regards Åke
Old 7th May 2006, 05:55 PM   #8
rdf is offline rdf  Canada
rdf's Avatar
Let me begin by stating I'm a solid state 'idjit', but if someone handed me that circuit to diagnose the first thing I'd do is remove the tubes and clip a couple thousand ohms across the interstage switch to see if the hum disappears or changes. The output stage gates don't appear to have any reference to ground.
Ears aren't microphones.
Old 7th May 2006, 06:26 PM   #9
On Hiatus
SY's Avatar
rdf: It looks to me like they do via the PS rails. Nonetheless, I don't see how that bias scheme could be stable.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
DIY Hybrid poweramp noise and hum problemHide this!Advertise here!
Noise problem on DAC IC DrVingTor Digital Source 0 3rd July 2006 10:17 AM
Noise Problem. raveenvijendren Solid State 0 14th November 2005 07:03 AM
Noise Problem Jackson Yaya Solid State 4 6th June 2005 07:08 PM
noise problem danyel Chip Amps 3 23rd February 2005 11:59 AM
HF noise problem jarkaa Chip Amps 1 6th February 2005 05:47 PM
Copyright ©1999-2017 diyAudio
