| diyAudio Sponsor | ||
hello all this is my first time workin with tubes i picked up this turn table /radio consol the other day with thinkin i could use the tube amplifier as a guitar amplifier to my surprise it was a unit that had able to work in stereo any way i stripped it down and was able to strip awy the radio unit and was left with a pre amp and then the amplificatin unit itself now i have a bunch of tubes left over most are valvo types and a couple of siemens and some telefunken my qustions are am i able to use this so i can bridge the amplifier and second is there any noob projects that i can make a tube type distortion pedal please if u need any more info i can post more
and yes im being carefull but bein electricuted been there done that |
#2 | |
Valvo, and telefunkens can be valuable if they are the right numbers. Worst case scenerio you have a lot of good donor parts for a better project! Trout |
#3 | |
Apart from that, list the valve numbers and how many of them there are - that will enable us to suggest what you can do. But first point, you DON'T normally bridge valve amplifiers - they aren't accurate enough, and the output transformers mean there's no point.
Nigel Goodwin |
#4 |
hey i apologize for my punctation grammar isnt my specialty .
The tubes i have are 2 ell80 ,3 ecc83 , 1 ef80 ,1 ech81 1 ef89 ,1 ec81,1 aem86 and a few more with rubbed off numbers . the reason i asked about bridging i should have asked if i could hook up my guitar on both left and right channels simuntaniously without to much interferance . I cant tell what kind of console it was,beacause there were no tags on it . Now there is a tag on the transformer that says nordmende r 89 not sure if that helps i would like to make a distortion pedal if i can with the left over parts there are a few resistors and diodes etc thanx |
#5 |
ELL80's are double output pentodes, so you have two push/pull amplifiers, one for each channel - the ECC83's are audio double triodes, used as phase-splitters and preamps.
Have a look at this circuit which I found with a quick google!.
Nigel Goodwin |
#6 |
thanx for the quick response nigel but for me that circuit is way to hard for me to understand . My knowledge in electronics is basic
ive been googlin it also and found lots of info i figure may be i will just use these channels seperatly |
| DIY Tube Amp Questions | john65b | Tubes / Valves | 95 | 24th April 2008 05:22 PM |
| Questions about first tube PSU! | luvdunhill | Tubes / Valves | 2 | 18th September 2007 06:06 PM |
| 2 Tube questions, | Trout | Tubes / Valves | 5 | 14th April 2006 09:57 PM |
| 24 bit / 192 kHz Tube DAC questions | Overlord | Digital Source | 4 | 29th April 2003 05:14 PM |
| Page generated in 0.11384 seconds (80.76% PHP - 19.24% MySQL) with 10 queries |
