diyAudio Sponsor
Old 26th April 2006, 07:27 AM   #1
trends is offline trends  Hong Kong
Default Help! 6DJ8 Tube Buffer Schematics
I want to make a 6DJ8 tube buffer. I'm looking for a schematics that is using low voltage, if possible single +ve voltage. I found most are +ve -ve voltage.
Old 26th April 2006, 07:36 AM   #2
pinkmouse's Avatar
SY's Heretical line stage, (search), is pretty simple, and sounds good. It does need two traffos, but I used a couple of junk box ones to good effect.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 26th April 2006, 08:21 AM   #3
Steve Bench's crossover is a buffer that uses the 6DJ8.
http://members.aol.com/sbench101/Crossover/xover.gif
Off course you must take the whole crossover network out of the circuit, that is. Hmm... should look like tha attached schematic.
This is redrawn from steve bench's circuit.I DON'T WANT TO CLAME I DEVELOPED IT - it is just to make thinks clear.
Old 27th April 2006, 07:44 AM   #4
Thanks pinkmouse & ErikdeBest. I will further study both of them.
Old 27th April 2006, 11:26 AM   #5
Default My found schematics
I found these two very similar schematics. Can they be modified to single +ve voltage?
Actually, what will be the expected performance difference between these two similar schematics?
Old 27th April 2006, 11:26 AM   #6
And, this.
6N1P for buffer instead of 6DJ8, 6922 JojoD818 Tubes / Valves 39 28th April 2010 12:17 AM
SE Tube Preamp circuit using 6922/6dj8 at low voltage(24volt) needed! anyone? tone Tubes / Valves 7 20th February 2010 12:11 AM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
6DJ8 / 6922 tube? nordhaven Tubes / Valves 25 27th April 2008 08:07 PM
Low Voltage Plate Follower 6DJ8 Buffer Power Supply mwl6m Tubes / Valves 50 3rd August 2007 07:50 AM
Page generated in 0.08820 seconds (70.56% PHP - 29.44% MySQL) with 11 queries
