diyAudio Sponsor
Old 24th April 2006, 04:07 AM   #1
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Default Help with bogen CH8
Hello all, I'm rebuilding this old amp for a friend. I'm working on getting a schematic, but in the mean time I'm replacing all the caps and will begin testing all resistors.
I have a few parts I need help identifying. The first is certainly a ceramic power resistor, but I don't know how to read it's markings. The second is, well, the picture speaks for it's self.
The only other parts I'm not sure of are two large resistors but I don't know how to judge the power rating by thier size. One is about 1.25" x 1/4" and the other is 1.5" x 5/16". The first one is pictured.
It's bands are Yel,Vil,Orn (I think)
The other is Red,Vil,Brn (I think) But it reads 450 ohms.
As far as the bulk of the resistors, is 1/2w adequate for replacement of the smaller carbon ones?
Yes indeed, a schematic would be nice.
Thanks!
Old 24th April 2006, 04:09 AM   #2
Proud Union Member
imix500's Avatar
Default Power resistor
Old 24th April 2006, 04:10 AM   #3
Proud Union Member
imix500's Avatar
Default ?
Old 24th April 2006, 04:11 AM   #4
Proud Union Member
imix500's Avatar
Default Resistor
One of the larger carbon resistors
Old 26th April 2006, 03:10 AM   #5
Proud Union Member
imix500's Avatar
Ok, any help on the mystery parts in the photos?
Thanks.
Old 27th April 2006, 03:32 AM   #6
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
post 3 is a molded mica cap
under 'mica capacitors'-just past half way
http://www.electronicsgenius.com/Tec...capacitors.HTM
resistor codes-
http://www.elexp.com/t_resist.htm
Old 28th April 2006, 03:49 AM   #7
Proud Union Member
imix500's Avatar
tomtt, thanks for the link. So if I'm reading it right it's a 500pf cap? The values of the resistors I can figure in my head, the colors are just really worn.
My question was towards the power rating of the resistors based on thier size. Any ideas? Thanks.
bogen amp karma Tubes / Valves 15 16th August 2011 10:45 PM
Bogen amp bobhedberg Tubes / Valves 1 20th May 2006 09:29 PM
Bogen CH8 imix500 Tubes / Valves 1 22nd April 2006 04:03 AM
Bogen DS-225 lpd Tubes / Valves 2 18th December 2004 05:18 AM
Bogen help sickss Tubes / Valves 0 2nd June 2004 01:25 PM
Page generated in 0.11820 seconds (69.30% PHP - 30.70% MySQL) with 11 queries
