Good tube DIY for EL34's?
Old 20th November 2002, 08:33 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Great!
Originally posted by Rino odorico
Hate to bother you about it, but when I print it...can't really read it very well. Could you if possible (please) e-mail it to me?
I'm pretty sure Frank just snagged these off the net (i've seen them both before), if so what you see is what you get. URLs to those sites would probably be more useful.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th November 2002, 08:35 PM   #22
frugal-phile(tm)
planet10's Avatar
Default Re: MATCH
Originally posted by fdegrove
The EL34s' should be matched for optimum performance.
Maybe ask a dealer to do that for you against a nominal fee?
Bill Perkins (PEARL in Calgary) does this, usually as part of his cryo regime.
dave
Old 20th November 2002, 08:38 PM   #23
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default PRINTING
Rino,
If I send you the same stuff it's not going to solve the printing problem.
Try to open them in a graphics program and split the pic into 2 or more sections.
Save the separate parts,enlarge them so you can read all that's on it and when printing those enlarged parts make sure your printer is set to "fit to page".
That should solve it.
Frank
Old 20th November 2002, 08:43 PM   #24
fdegrove's Avatar
Default NOT IN THIS CASE.
Dave,
On this occasion you put them up here so they're local.
I usually have to resort to urls since I have this problem uploading anything from my local disk.
The site is protected against mirroring so no luck there and printing from it won't solve the clarity problem either.
Just for info,
Frank
Old 20th November 2002, 08:46 PM   #25
Rino odorico is offline Rino odorico  Canada
Default Cool,
Cool, thanks Frank.
Can't wait to try some of this out. I can see it now...a mad scientist in the making...mmwaahhh, ah hahaha (tyring to type in my best scary voice)
Rino Odorico
Old 20th November 2002, 08:50 PM   #26
frugal-phile(tm)
planet10's Avatar
Default Re: NOT IN THIS CASE.
It is a little trickier to get them, but i just drag them out of the browser on to my desktop (it may be trickier under windows), change the *.php to *.jpg or &*.gif and open it in PhotoShop (or graphic converter or back in my browser).
The ones i posted have also been cleaned up a bit (they are actually gifs) from what Frank sent.
dave
Old 20th November 2002, 08:54 PM   #27
fdegrove's Avatar
Default WINDOZ
Hey,
Anything a Mac can a window can too.
Works in Windoz too thanks to Mickeysoft.
Sorry Dave 1-1?
Frank
Old 20th November 2002, 08:58 PM   #28
Default Oh great...
Oh great, now look at what I've started!
Old 20th November 2002, 09:08 PM   #29
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
2 grown men boasting about their gui's!
Old 20th November 2002, 09:11 PM   #30
fdegrove's Avatar
Default NO WORRIES.
Rino,
Dave knows where I'm coming from so don't loose sleep over the little games here.
BTW is the power of a single PP pair enough for you?
Cherio,
John,
Better that than boasting about.....
Frank
Good tube DIY for EL34's?Hide this!Advertise here!
EL34 tube amp that needs work on el34ecc88 Tubes / Valves 0 17th December 2008 08:05 AM
G.E. 6CA7/EL34 - any good? drgonzo2 Tubes / Valves 9 12th November 2007 03:28 AM
Is this a good choice for El34 PP dstockwell Tubes / Valves 5 14th July 2005 06:52 PM
Preferred tube? KT88 vs. EL34 G Tubes / Valves 2 20th May 2005 04:29 PM
EL34 vs. 6L6GC for 1ST DIY Tube Amp? pjkunz Tubes / Valves 4 17th December 2001 02:51 AM
Copyright ©1999-2017 diyAudio
