Good tube DIY for EL34's?
Old 20th November 2002, 06:48 PM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default FLAMIN' FIREWALL.
Hi Dave,
Guess it was an open door.
I'm pretty sure it's the firewal in the router acting up on me.
Since that sits with Siemens I'll have to ask them for a dedicated port.
You know these guys,they're paranoid as hell.
Thanks for posting the piccies,
Frank
Old 20th November 2002, 06:51 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
And the other one. I think Frank intended on sending a power supply but this is another example of PP EL34.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th November 2002, 06:59 PM   #13
frugal-phile(tm)
planet10's Avatar
Now both those circuits have too many ECC83s in them for my taste (i know you have new ECC83s -- what kind, on eBay they may fetch enuff to pay for the iron -- especially if they have little diamonds on the bottom).
Here is what i'm going to base my Dyna ST70 on:
this schema and a couple accompanying ones (and a picture) can be found at the http://www.vacuumstate.com/schematics.htm]Vacuum State[/URL] web site (you will have to scroll down a bit.
dave
Old 20th November 2002, 07:16 PM   #14
On Hiatus
SY's Avatar
"Boucles de contre-rčaction" sounds sooooo much more romantic than "feedback loops.
Old 20th November 2002, 07:26 PM   #15
fdegrove's Avatar
Default CHEVEUX BOUCLES.
Correct,only I didn't want to chop of the circuit part since it may be usefull to others.
Naturally it will need some mods to work with the first circuit and I'd put some bigger caps behind the chokes.
This one circuit that benefit from the brute force approach especially when crossing to Class B operation.
Sy,
Charmant,no?
All,
If anyone needs a translation of the french text under that first circuit I'll be happy to do it.
Cherio,
Frank
Old 20th November 2002, 07:38 PM   #16
Rino odorico is offline Rino odorico  Canada
Default Hey, talk about info!
Wow, thanks guys! And the circuits don't look that bad to build! Now, just to choose which one to do...
As far as the tubes...been a while since I looked. From what I can remember about the ECC83's, they are not "Matched" or in any order. Darn can't remember what make. Put it to ya this way, I have approx 20 of them. They actually can from Luxman Canada's service depo.
The EL34's approx. 15-20. I know that those are not in matched pairs. What make are they, well they say Luxman directly on them...so who ever they used back then.
Frank, never seen anything like that pre-stage before...4 tubes?
Rino Odorico
Old 20th November 2002, 07:42 PM   #17
On Hiatus
SY's Avatar
Ah, Frank, I wouldn't have guessed that you are a Walloon. And even if a Flem speaks French, he won't admit it.
Old 20th November 2002, 07:56 PM   #18
fdegrove's Avatar
Default MATCH
Hi Rino,
Actually what you see are just two 12AX7As',each contains two triodes that should be matched already internally.
The diagram you see is very well thought out and is known to be able to drive even difficult loads with ease.
The EL34s' should be matched for optimum performance.
Maybe ask a dealer to do that for you against a nominal fee?
Yur Lux tubes are likely to be Japanese jobs built by Matushita,NEC or Toshiba depending on age.
Sy,
Mon ami,you izz wrong in yourrrr assumption.
Je suis Flemish,and proud of it.
Fact is most Flems do speak French whereas very little Wallons speak Flemish.
Put a Wallon and a Flemish guy together and within a second or two they'll speak in french to each other,never,never the other way around.
Frank
Old 20th November 2002, 08:14 PM   #19
tiroth is offline tiroth  United States
Thanks for the schematics guys!
Old 20th November 2002, 08:17 PM   #20
Default Great!
Great, should have known...as per the reading I have been doing..."some triodes will actually be doubled internaly" or something like that (can't remember the words perfectly, but I get the jist).
Looks like a great starter amp Frank. Hate to bother you about it, but when I print it...can't really read it very well. Could you if possible (please) e-mail it to me? Now here's the topper...and anything else you have on it?
rodorico@ca.telus.com
Good tube DIY for EL34's?Hide this!Advertise here!
EL34 tube amp that needs work on el34ecc88 Tubes / Valves 0 17th December 2008 08:05 AM
G.E. 6CA7/EL34 - any good? drgonzo2 Tubes / Valves 9 12th November 2007 03:28 AM
Is this a good choice for El34 PP dstockwell Tubes / Valves 5 14th July 2005 06:52 PM
Preferred tube? KT88 vs. EL34 G Tubes / Valves 2 20th May 2005 04:29 PM
EL34 vs. 6L6GC for 1ST DIY Tube Amp? pjkunz Tubes / Valves 4 17th December 2001 02:51 AM
