Good tube DIY for EL34's? - Page 4 - diyAudio
Old 21st November 2002, 01:04 PM   #31
Default Power...
Hey Frank,
Hum, 2 PP El34's...is that enough power? I would have to say yes, unless you have something up your sleave. Now the question (as I sip on my morning coffee) is, should I even ask...yes I should.
Ok Frank, I'll ask...why, what do you have in mind?
Rino Odorico
Old 21st November 2002, 01:19 PM   #32
diyAudio Senior Member
fdegrove's Avatar
Default WHAT IS WAS THINKING
Well, I was thinking about a multiple PP of El34s but we better forget about it.
When I think I run a pair of self-made bookshelf speakers with a set of 2A3s PSE putting out a couple of Watts to more than satisfying levels....
No,I thought also that you could add a volumecontrol at the input
with a bypass connection straight in.
So for CD you could connect to that and for sources requiring a preamp you could then use the direct connection.
After all it is easier and less costly to drive speaker cable of some length than to use long interconnects.
Frank
Old 21st November 2002, 10:18 PM   #33
jam is offline jam  United States
jam's Avatar
Dave,
Please keep us informed on your vacuum-state EL-34 project. I gathered the parts to build one but got distracted. Have you heard a built unit? It looks like it could be something special.
Jam
Old 21st November 2002, 10:35 PM   #34
fdegrove's Avatar
Default MISSING PARTS
Not much is missing really.
Add the CCS and you're there.After all it would work without it or have I missed out on something?
Cherio,
Frank
Old 22nd November 2002, 01:38 AM   #35
frugal-phile(tm)
planet10's Avatar
I haven't heard one, Dice45 has heard one that would be close. I have a number of other amps that are also candidates for this treatment. The 1st one out the gate will probably be a Scott LK48 with EL84s.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd November 2002, 01:46 AM   #36
fdegrove's Avatar
Default SMALL TELETUBES...
A ccs treated EL84?
Sound like breakfast in bed to me.
Of the small power tubes I must say I prefer the EL84 over a lot of them till you hear the EL86.
Shear magic...
Ciao,
Frank
Old 22nd November 2002, 03:59 AM   #37
frugal-phile(tm)
planet10's Avatar
Default Re: SMALL TELETUBES...
I'm hoping so. If the 1st one works out, i have Dyna iron for a set of monoblocs.
I haven't run across this one yet... have you heard the SV83?
dave
Old 22nd November 2002, 09:35 AM   #38
fdegrove's Avatar
Default EL84
Hello,
Yes I have toyed with that one.
It isn't bad at all but i still prefer the NOS E84L/7320 made by Siemens.
The russian E84LM,the military one,is excellent as well if you want a bit more top end and speed.
The EL86/6CW5 requires a different OPT but can really sound impressive.
An excellent noval power tube.
Ciao,
Frank
Old 22nd November 2002, 06:17 PM   #39
frugal-phile(tm)
planet10's Avatar
Default Re: EL84
Got any "maps" in your collection? From what i could quickly gather this would use an OPT in the same general impedance range as a 2A3?
dave
Old 22nd November 2002, 07:01 PM   #40
fdegrove's Avatar
Default EL86
Hello,
Most of what I found are Philips designs,OTL for a 800 Ohm speaker.
Naturally an OPT could be used for 16-8-4 Ohm impedances.
I've owned an OTL amp like that and much to my surprise it did drive my 8 Ohm speaker very well.
http://www.cs.uu.nl/~gerard/RadioCorner/Articles/SerBalOut.htm
DATASHEET
INTERESTING STUFF FOR ALL OF US
AN ITALIAN SITE I OFTEN USE (PROTECTED ZONE)
And there must be more I could dig up....
I've seen prices on this tube from 5.00USD to 20.00USD depending on sources and manufacturer.
Frank
EL34 tube amp that needs work on el34ecc88 Tubes / Valves 0 17th December 2008 08:05 AM
G.E. 6CA7/EL34 - any good? drgonzo2 Tubes / Valves 9 12th November 2007 03:28 AM
Is this a good choice for El34 PP dstockwell Tubes / Valves 5 14th July 2005 06:52 PM
Preferred tube? KT88 vs. EL34 G Tubes / Valves 2 20th May 2005 04:29 PM
EL34 vs. 6L6GC for 1ST DIY Tube Amp? pjkunz Tubes / Valves 4 17th December 2001 02:51 AM
Copyright 1999-2017 diyAudio
