Old 24th April 2006, 06:58 PM   #11
Well, i did replace the HT fuse and the amp played for about 30 seconds before blowing the fuse again. I have been told this could be caused by worn out tubes. The amp has mullard el34 power tubes and JJ 83 preamp tubes. Would it most likely be the power tubes or preamp?
Old 24th April 2006, 07:37 PM   #12
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Good. Assuming you replaced the fuse with a correct spare, something seems to be wrong with the electronics.
The HT fuse is the 500mA slow blow. If it were faulty rectifiers, D105 - D108, the fuse would probably blow instantly. Worn out tubes can be but first check capacitors like C112, C111, C110, C109.
/Hugo
PWM signal to Audio signal possible? thx_dts71 Class D 2 11th November 2008 02:38 PM
JTM60 capacitor question joelchoy Tubes / Valves 3 15th February 2008 05:32 AM
Marshall Signal Path Help SaveTheMarshall Instruments and Amps 3 6th May 2007 03:02 PM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 12:47 PM
Page generated in 0.09747 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
