6HV5A Single Ended Amp - Page 8 - diyAudio
Old 16th June 2010, 02:29 AM   #71
Tubelab_com's Avatar
Or is it just that cliplead parasitics are driving you nuts?
I have been told over and over that you can't build an amp using clip leads. I have never been one to listen very well so I did it......about a zillion times. Yes there are some tubes that you CAN'T clip lead together the 5842 / 417A is one and the 6EJ7 is another. It appears that the 6HV5 and friends are also on this list. Note that tubes with lots of transconductance seem to be clip lead unfriendly.
Note the method of construction used in these fully functional amps.
As for 6HV5, might see if its any more stable when Schaded to lower Mu? Particularly DC coupled 100% PG without voltage gain. That could be an
interesting mode of operation in A2, if you could toss some direct coupled
sand between Schade and Grid without a phase shift back to instability???
That is where I may go next. Reduce the gain AND the output impedance via local feedback to make a $1 triode sound like a $50 triode.
Waitaminute... I got 13pin sockets.
Then you really have something weird, since they should be 12 pin sockets. Others have suggested sky wiring octal or 9 pin sockets into this board, but that is too much work. There are dozens of 12 pin tubes that work in this board, many of them cheap. 6GV5's were on the dollar menu until this board came along.
Tube testers may tell you what the Gm is under rather low powered conditions. They don't tell you much about waht happens at 30 watts though.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 16th June 2010, 02:45 AM   #72
wrenchone's Avatar
I agree that a 6HV5 or one of its siblings might be a natural for a partial feedback (Schade-style) amp as a way of utilizing all that excess gain. I was thinking of a modest triode-pentode pair (people can insert their faves) for the front end, with the pentode as voltage amp and the triode as cathode follower to direct drive the grid. I would look for a tube that had a medium-mu, relatively high gm triode (get out your tube manuals). The amp might end up with enough feedback, even with a Schade-style setup, to sound solid state-ish...
Old 19th June 2013, 02:01 PM   #73
Vinylsavor's Avatar
Hi!
Ever wondered how such a beam triode looks inside?
Check out my post about this tube with photos of the grid:
VinylSavor: Tube of the Month : The 6HV5A
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 20th June 2013, 02:02 AM   #74
Thanks Thomas, very interesting!
Old 20th June 2013, 03:06 AM   #75
multi is offline multi  Australia
Default 811A SE
Nobu Shishido's SE using the 811A
430 volts supply for 13.5 watts. 3.5K transformer
I made a 811A SE but used a 6BX7 as a cathode follower to drive it.
Fewer transformers the better.!!!
Phil
Old 20th June 2013, 04:55 AM   #76
wrenchone's Avatar
The 6HV5A must have been one of the largest frame grid triodes ever made. I wonder what the reject rate was on those tubes - maybe they had a special jig for grid-to-cathode spacing.
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Single Ended EL-34? jaymanaa Tubes / Valves 11 28th March 2006 10:32 PM
42 single ended ThSpeakerDude88 Tubes / Valves 38 19th November 2005 10:02 PM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright 1999-2017 diyAudio
