diyAudio Sponsor
Old 18th April 2006, 10:00 AM   #1
zanash is offline zanash  United Kingdom
Default MF x10v3
Having open up one of these beasts it's clear to see that the four transistors in the output are cooking the pcb. There is considerable disclouration of the pcb track [tranies using these to sink heat away from themselves]. If this is left unchecked it may cause failure of the unit.
I would use a heatsink like rs part 507-4753 .
I've bought this up as a "heads up" for anyone who has this unit, and therfore should check it out.
I have search but found nothing !
Old 18th April 2006, 01:51 PM   #2
that's because mf is a pile of shiite, its made in taiwan now for chicken shittt money,
...whilst michaelson pays himself millions, if he lied about class A, can you trust him?
he also doesn't use his own turntable, still a thorens 124, as the mf isn't good enough.
check here
MF x10v3, xcans v3, trivista, a5 outputstage
Old 18th April 2006, 03:17 PM   #3
Can't disagree .......
its not my cup of tea either.
I'm just the modder of someone elses gear. But thought people should be aware of the possible problem..!
Old 19th April 2006, 09:21 AM   #4
Check the temp this morning the transistors are running an unhealthy 80 degrees c ..............I'm going to heat sink the little sods.
MF x10v3, xcans v3, trivista, a5 outputstage lt cdr data Digital Source 12 30th April 2007 02:40 PM
Page generated in 0.06962 seconds (65.19% PHP - 34.81% MySQL) with 10 queries
