8068
8068
Old 19th November 2002, 12:26 PM   #1
jackinnj is offline jackinnj  United States
jackinnj's Avatar
8068
Default 8068
I aquired a Kepco power supply with 8068's -- of course 2 were missing. From what I can determine I can probably substitute some Eimac bottles with a lot of rewiring, etc. Anyone out there know the specs on these things. The usual suspects don't seem to have any data.
Old 19th November 2002, 12:38 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default 8068
Hi Jack,
Don't you want to add the missing tubes or do you want to rebuild?
Here's a source for the 8068:
http://www.thetubestore.com/nos-8068.html
If i can find a specsheet I'll add it.
Frank
Old 19th November 2002, 01:27 PM   #3
LaMa is offline LaMa
quote from the website:
Availability: Out of stock
Old 19th November 2002, 01:31 PM   #4
fdegrove's Avatar
Default 8068
I'll give my suppliers a call but apparently Kepco have a kit that uses FET's to replace the tubes.
KIT
Ciao,
Frank
Old 19th November 2002, 01:54 PM   #5
fdegrove's Avatar
Default DATASHEET
he,he found a datasheet and some more info:
SVETLANA
ELEX
elexs@aol.com
DATASHEET
May have stock here:
ALLTRONICS
Frank
Old 19th November 2002, 02:09 PM   #6
jackinnj's Avatar
8068
Default Well
at $50 a pop I think that I can wire up either IRFBE30's or BUZ80A's in series more cheaply.
8068Hide this!Advertise here!
data sheets for 7239 and 8068 nhuwar Tubes / Valves 3 20th May 2008 09:05 PM
