Just another PP...
Just another PP...
Old 16th April 2006, 02:58 PM   #1
jane is offline jane  Norway
jane's Avatar
Default Just another PP...
This design is a result of a too high B+. In my case I had to deal with ~380VDC together with a pair of EL84s and a ECC83 for driver. The question was where to burn away the not needed voltage. Here, the cathode resistors (R6/R7) did the trick. The voltages over these are ca 100V, which makes it possible to do the driver stage direct coupled. The feedback is partial, ~10dB from plate back to grid at the output pentodes and ~10dB loop feedback.
Not that much more to tell -- it's just another small amp.
Mini PP schematics:
On the work bench:
Life is hard - Then you die.
Old 16th April 2006, 03:56 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Good! There also could be a possible adaption for cheap E/PLC86-82 etc etc...
What about the diodes between the power tubes grids and cathodes?
Old 16th April 2006, 04:56 PM   #3
jane's Avatar
They are there to limit the Ugk voltage at start up. If not present this voltage will be equal to B+ before the circuit is stabilized.
I'm not sure how bad this is for the tubes, but 1N4148s are quite cheap (and Iíve got a box full of them)
Old 16th April 2006, 07:09 PM   #4
Giaime's Avatar
Oh yes, in DC coupled designs it's better to use it. Althought I've never seen a faliure due to the omission of that...
Probably it's related to the warmup times of the drivers versus the one of the power tubes.
Old 16th April 2006, 07:26 PM   #5
Yvesm is offline Yvesm  France
Yvesm's Avatar
So simple !
Congrats.
Yves.
Old 17th April 2006, 12:33 PM   #6
ttan98 is offline ttan98  Australia
JAne,
where do you get the pCB with pins mounted on it?
thanks
Old 17th April 2006, 01:09 PM   #7
jane's Avatar
Partsconnexion: http://www.partsconnexion.com/catalo...nalStrips.html
Old 17th April 2006, 01:57 PM   #8
Thanks Jane,
please report back the results you get, eg Distortion figure as the feedback is quite low.
Old 17th April 2006, 04:41 PM   #9
Jane,
BTW what input tube would you use and what current will you run it at, just wondering..
Also you may need a balancing pot at the cathode of the input tube to balance the anode so that the EL84 can be correctly bias. I like the Jfet Yves uses for his amp. at the cathode of the input tube to determine the cathode current... Just a thought...
Old 17th April 2006, 05:36 PM   #10
jane's Avatar
I have some ECC83s that I might use...
Since Vak is approx 100V, I suppose I have to "starve" the input tubes a little bit.
Ia about ~0.5mA seems to fit in this case.
The EL84s will have quite large cathode resistors (3-4k), so a few volts out of balance will not alter the anode current too much. That is the reason why I donít use a shared cathode resistor.
Just another PP...Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
