Leak Stereo 20 questions - Page 3 - diyAudio
Old 28th April 2006, 04:33 PM   #21
kevinkr's Avatar
Accurate vacuum tube volt meters, and for those who could afford them good scopes from outfits like HP, Tek, Fairchild, etc.. I'm sure the UK had at least one comparable instrument manufacturer and metrology labs with high accuracy standards to calibrate them. It wasn't totally the stone age ya know...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th April 2006, 04:00 PM   #22
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default It's those doggone transformers...
The problem was not so much measuring to 0.1dB - there were test sets having scales to 0.1dB resolution, it's more that such instruments were designed for professional (balanced) audio and they inevitably used a transformer for the input balancing. Despite various myths, 600R was not universal, so these test sets also needed to be able to present a high impedance load (typically 50k) and that's where the problem arises. The input transformer required to be able to present a 50k balanced load was generally not flat to 20kHz +/-0.1dB. It was only when op-amps enabled "electronically balanced" inputs with decent CMRR that test sets magically became flat to 300kHz +/-0.05dB or better.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th April 2006, 09:21 PM   #23
On Hiatus
SY's Avatar
My old Heathkit AC VTVM ran straight in, single-ended with a scope probe. It's been some decades now since I lost it, but I'm pretty sure it had 0.1dB resolution. It was designed for service people and amplifier clinics, not broadcast/studio use. I'd guess there were equivalent units from Eico, HP, and the rest of the usual suspects.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th April 2006, 11:57 PM   #24
EC8010,
From what I can remember we had General Radio stuff at varsity and early at the CSIR, all with 600 ohm output impedance, although I am not saying that was general. The Leak TL12-type circuit with pentode input would not have suffered much until the source output impedance went above 10 K.ohm. It is these triode-input stages that would need a source impedance spec. for tests and amplifier output specs.
LEAK stereo 70 cutting out Minimuslover7 Solid State 10 24th August 2009 04:56 PM
Xindak attenuation for use with Leak Stereo 20, help please camperman Tubes / Valves 15 20th May 2008 07:12 PM
Leak Stereo 20 clone? possibly with 6V6? bikehorn Tubes / Valves 26 29th March 2007 01:52 AM
Leak stereo 70 fault harrygrey382 Solid State 16 25th February 2007 04:07 PM
Mods on leak stereo 20 bronto64 Tubes / Valves 22 26th April 2004 08:27 PM
Copyright 1999-2017 diyAudio
