10M45 CCS, what am I doing wrong ?
Old 15th April 2006, 06:49 AM   #1
jj2 is offline jj2  United States
Unhappy 10M45 CCS, what am I doing wrong ?
install 10m45 with 46ohm resistor with give me about 40 ma on the plate(320V) of my sun 2a3.
but a I am getting is a cracking sound of music .
cathode is 720 ohm with 20uf solen cap.
without the ccs it plays fine.
Thanks for any help.
Old 15th April 2006, 07:12 AM   #2
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
These chips have a tendancy to oscillate. See Tubelab.com for some ways to stop this.
Old 15th April 2006, 01:56 PM   #3
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
The 10M45 will oscillate causing a crackling sound, and sometimes dead chips. Put a 1 K ohm resistor in series with the gate lead as close to the chip as posible. This has fixed it in all of the cases that I have seen.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 15th April 2006, 03:07 PM   #4
Angry still no go
thanks tubelab.com
Installed 1K resistor, still no go.
replace 46 ohms with var resistor in negative pin of 10m45.
adjust var resistor while measuring cathode current, at 57ma it stop going up, var resistor measure at 18.2 ohms.
music come out fine but not great.
questions:
1) do I have to remove cathode cap & resistor, or how do I find out what size resistor to use with CCS on the plate ?
2) Is 18.2 not way to low for 10m45? according to the IXYS chart for 60ma it should be 40 ohms.
Thanks for the help
Old 15th April 2006, 03:49 PM   #5
How did you install the 10M45? Where in this circuit did you put it?
Old 15th April 2006, 05:38 PM   #6
rdf is offline rdf  Canada
rdf's Avatar
Default Re: still no go
My experience has been the resisitor vs. output current graph in the datasheet doesn't mean much. The correct value also seems to vary sample to sample. Just use whatever works. I solder a mini ten-turn to the pins and keep it there until the circuit is ready for final build, which in my case usually means they never come out.
Ears aren't microphones.
Old 15th April 2006, 10:32 PM   #7
Tubelab I install it at the plate of the 2A3 after the 2.5k tap of the output transformer.
thanks.
[IMG]C:\Documents and Settings\jj\Desktop\sun ccs.jpg[/IMG]
Old 16th April 2006, 02:54 AM   #8
You can't put a CCS here. A CCS has a very high impedance and will severely distort the signal if put in series with the signal path.
Try puting the CCS in place of the cathode resistor. Leave the capacitor in place. The cathode capacitor becomes more important now since it is the only low impedance path to ground.
Old 11th September 2014, 06:32 PM   #9
johnferro is offline johnferro  United States
Tubelab - I know I am resurrecting an old thread but I have a 10M45 question along the lines being discussed. I would like to use this device as the tail of a LTP (12AT7). I was going to put a 470 ohm resistor from G to ground to stop any oscillations, and a 10 ohm and a 2K pot from K to ground to dial in the proper current (10 ohm to measure current). I am looking to dial in about 5 mA through the LTP. My question is do I connect the "A" terminal directly to the cathodes of the LTP? Does a certain voltage need to be developed on the "A" terminal? Finally, how do I calculate the output impedance? I will be driving fixed bias KT88s which have a low (100K) input impedance and would like to know if this will work.
10M45 CCS, what am I doing wrong ?Hide this!Advertise here!
It's raining 10M45's! leadbelly Tubes / Valves 12 26th May 2011 06:30 PM
IXYS 10M45 CCS IC question zobsky Tubes / Valves 19 26th July 2008 09:15 PM
CCS 10M45 in Cathode of CF Driver danFrank Tubes / Valves 13 5th March 2007 10:41 PM
10M45 Mu-Stage Idea? sgerus Tubes / Valves 44 1st March 2007 04:14 PM
Wanted IXYS 10M45 guglielmope Swap Meet 0 29th June 2006 09:10 AM
