diyAudio Sponsor
Old 14th April 2006, 07:26 PM   #1
gary f is offline gary f  Canada
gary f's Avatar
Default Power supply help!
Simple question I guess
I'm building this circuit to supply plates for my amp at 315 and 305 volt. Main transfo is 275-0-275 volt.
Right now, in theory, I should get less than 300 volt at point A and B, but I get 420 volt approximately. WHY?
I should have maybe 250 volt. Am I correct?
Thank you
F
Old 14th April 2006, 07:43 PM   #2
wa2ise is offline wa2ise  United States
wa2ise's Avatar
If there isn't enough of a load, the voltage will be higher. With no load, the filter caps will eventually charge up to 275 times 1.414 volts, about 385V for a powerline at 120V, but if your powerline is a little higher, and the 275-0-275V secondary is its voltage under load, these two factors would put the unloaded output voltage even higher to the 420V you're seeing.
Old 14th April 2006, 07:46 PM   #3
gary f's Avatar
There is no load right now...
Did not thought that this could cause a problem....
Should I put my tubes in and try?
F
Old 14th April 2006, 07:49 PM   #4
gary f's Avatar
And my power line is 125 volt AC. Very interresting
F
Old 14th April 2006, 07:54 PM   #5
Uchi Deshi's Avatar
Did you measured it without load?
Old 14th April 2006, 07:56 PM   #6
gary f's Avatar
Yes I did. No load.
Is that bad??
F
Old 14th April 2006, 07:58 PM   #7
Uchi Deshi's Avatar
Yes. Absence of load causes higher voltage.If you convinced that your amp is good you can, but better solution is putting high power resistor.
Old 16th April 2006, 05:06 AM   #8
Sheldon is offline Sheldon  United States
http://www.duncanamps.com/psud2/
PSUD is your friend. It's free, it's easy, it works.
Sheldon
Old 16th April 2006, 09:52 AM   #9
lndm is offline lndm  Australia
Is your transformer an old one that would have given 275/0/275 back when mains voltage was lower? Your result does not seem surprising. The resistor will develop a voltage drop only after there is current running through it. Connect your amp and the rails should come right down.
Old 17th April 2006, 12:27 PM   #10
Sherman is offline Sherman  United States
F
You should also try measuring the AC voltage with a true RMS meter. I believe you'll then find your AC mains at 120V or less.
--Sherman
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.10457 seconds (74.30% PHP - 25.70% MySQL) with 11 queries
