Bi-amp Between Tube, and SS
Old 18th April 2006, 05:29 PM   #11
jtsjf is offline jtsjf  United States
I'm doing exactly this- bi-amping with 300B and a gainclone into a Khorn. I highly recommend it- it sounds great. To avoid all the crossover guessing problems, I use a digital crossover. In my case, a behringer dcx2496, but there are many other choices. Some people use a dedicated computer, some build their own. The advantage is you can set your crossover freq. and type (and process the signal) before it ever gets the amp.
Old 19th April 2006, 01:16 AM   #12
phn is offline phn  Sweden
phn's Avatar
This is old news on this forum. But some call the Sakuma system the best there is. Now, this is not for the beginner. But bi-amping is definitively a way to go. I have too little experience myself, and only with identical amps. I still thought it was an improvement. Placebo effect? Who knows? I still think it's a very interesting option.
Bi-amp Between Tube, and SSHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Copyright ©1999-2017 diyAudio
