| diyAudio Sponsor | ||
I didn't want to commit Thread-jacking, however I have another Bi-amping question
I would Like to use my SS amp for bass, and my Tube amp (under construction) for Mid, and High, My Beloved JBL E60s have termainals that allow for easy bi-amping, however I do not know if I need to do something special to not Ruin the tube amplifier when I do not allow the bass frequencies to pass to the speakers. Do I need some extra circuitry in either the input line, or the output line? Or Either!??! Please help, Thank you -Alex |
#2 |
Hi Alex,
First question is do your speakers use external jumper bewteen the mids/high and the bass binding posts. If yes then bi-amping with your solid state amp is possible. Your next problem will be amplifier input sensitivity. You may need some sort volume control on the bass amp to match the out with the mids/highs. You may have to do a passive volume control on the bass amp. The real big question is where does the JBL cross over to the midrange. If the bass driver crosses over at fairly high frequency then you may not be pleased with the results of the bi-amp set up. You do not have to worry about what happens to the cut off low frequencies of you tube amp. There maybe a different interaction between the tube amp and the mid/high freq. cross over. You will most likely get a little bit of a different sound because the tube amp is now seeing a different load than when it was seeing the woofer load in parallel with the mid/high. The only way to tell if bi amping will work for you is to try it. |
#3 |
Hey, Thanks for the post
Yes, I do have External Jumpers. The Crossover frequencies are 1000, and 4000hz (I didn't even have to look it up) What do you mean by passive volume Control on the bass amp? The other problem/question is a little more curious. My Speakers have a Dome tweeter, the Midrange is however is Driver, and cone. Will the presence of a this tweeter mess up the impeadance of the tube amp? |
#4 |
The passive volume comtrol would be level controls before the bass amp used to match the output levels of the woofer to mids and highs. Sometimes when you split a cross over the output levels maybe unequal between the woffer and the mids and highs. So you will need some kind of level control to match the outputs. This also is useful if the input sensitivity of the woofer amp is higher than mid/tweeter amp. This lets you balance the sound of the speaker.
#5 |
The dome tweeter shouldn't cause any problems with your tube amp. Tube amps tend to be a bit more forgiving when it comes to impedence. Try running the mids and high at four ohms also. Not just eight ohms.
#6 | |
#7 |
Sounds good, so just to make sure, If I try both the 4, and 8 ohm taps (at seperate times, obviously) nothing is going to explode? using this amp for mid/high should improve the sound quality of cheaper output transformers right?
#8 |
You will have no explosions. It will sound better on one or the other impedence taps. This will have no effect on the sound of the output transformer. Poor sounding output transformers will not sound any better in a bi-amp set up. Quite the contrary it can sound worse.
With your speaker's cross over point at 1000Hz you will be listening to the solid state amp for all of the vocals. Female formant is about 240Hz and the male formant is about 170Hz. Your going to be listening mostly to the solid state and the tube amp will be used mostly for upper mids and highs. Something to think about. |
#9 |
Honestly, I can make any real deiscions untill everything is built, and I can mess around with it, then I will find my optimal set-up whether it be both SS and tube, or just tube
#10 | |
Banned
This is what i would do Connect it test it try it out. I know a few people including my self that does this. Class a Or a A/B amplifier for the bass and then a pair of stereo tube amps for the top end mid / tweeter. In total of 3 amps. |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.10239 seconds (83.87% PHP - 16.13% MySQL) with 10 queries |
