| diyAudio Sponsor | ||
I've been asked to show the power supply I'm using with my preamp design posted in the "tube preamp" discussion - so here is the circuit first:
#2 |
and the power supply...
#3 |
Thanks Joel
Your power supply circuit is quite interesting. I was wondering ... a choke is not needed? Would there be an advantage of having a choke and a RC network? Its another newbee question.. Thanks Joe |
#4 | |
diyAudio Moderator Emeritus
burnedfingers said:
This is because the average current of a class A stage is constant. However, as soon as you start getting any asymetry, the current varies. As a matter of fact you can check exactly how much 2nd harmonic distortion a class A stage has, by measuring the change in consumed current. So, the answer to the question is: It depende how loud you want to play it. If you want to get the max out; go for a lower impedance choke smoothed circuit. If you want to economise, and don't want it loud. Use resistors. Cheers, |
#5 |
Exactly what John said.
But you'll find that, whether used as a linestage, or to drive headphones - you will never need to push the tubes in this. There is plenty of gain, and a low enough output impedance to handle either task. A choke will only add cost... to this project. (I really do love chokes people! I swear. But you just don't need one all the time) |
#6 |
No, you probably don't need a choke there. But you might want to bypass that last filter cap with a film cap of a uF or so. A scope or some headphones and a cap will tell you if that's effective.
I didn't read the other discussion- why use a 6SN7 in the first place for this application? It's a great high voltage driver that can source some current, but for a CF intended to pass a couple of volts at most, a higher gm tube with higher mu might be a better choice from the standpoints of source impedance and distortion. Don't misunderstand me, a 6SN7 will work OK, it's just not optimal. |
#7 | |
diyAudio Senior Member
I agree higher gm is what makes a CF sing. Even wouldn't mind a penthode there. Quote:
You often get the effect"Who stole the bass?" when bypassing. Cheers,
Frank |
#8 |
Well, if there's low frequencies moving around on the rail, you'll be able to spot it with the scope/phones. Though I don't see any reason why this should be greater with a bypass in place; the main effect of a bypass cap is seen at frequencies where the elytic is starting to get inductive.
I agree that a pentode would work well as the CF. For triode purists, a high gm triode (or a pair paralleled as Joel is doing with the 6SN7) will do nearly as well, but one generally has to accept 7 or 9 pin envelopes. |
#9 | |
IMO it is essential to have a large enough resovoir; that probably means it's going to be a bit inductive - so bypass it. But in doing do remember; youve made a parallel tuned circuit at "some" frequency. Best to avoid 'lytics if you're a puritan. Best buy some shares in a PIO company. Cheers, |
#10 | |
| Which 6SN7 preamp should I build? | chrisvw | Tubes / Valves | 48 | 12th August 2010 12:08 AM |
| 6sn7 Preamp power supply | ambience exists | Tubes / Valves | 27 | 26th August 2008 12:12 AM |
| Help with 6SN7 preamp | tubedude63 | Tubes / Valves | 7 | 9th October 2006 12:31 AM |
| Joel's 6SN7 preamp (photo) | Original Burnedfingers | Tubes / Valves | 48 | 2nd March 2003 12:00 PM |
| Preamp with 6sn7 & 6sl7 SRPP ??? | Gregouille | Tubes / Valves | 4 | 18th June 2002 10:41 PM |
| Page generated in 0.10892 seconds (77.79% PHP - 22.21% MySQL) with 11 queries |
