| diyAudio Sponsor | ||
#11 |
With a ground at the (-) input of the chokes and at the (-) output they are shorted... unless one of the two ground symbols isn't connected anywhere...
Normally in this circuit, the ground is at the output of the filter, and the (-) input floats at some volts negative. A small additional R-C filter in the (+) lead (just a resistor - capacitor is already there) can take care of any noise that is coupled through common mode or via the choke's capacitance to ground. |
#12 |
If you use a "common" choke in the neg to ground side of the power supply...you then disturb the ground for all the rest of the circuits.. You now introduce a ripple in ground ...so the ground is bouncing.... This may be fine in RF equipment...but in Hi-End audio the sensitive pre-amp stages will have a noisey ground as reference..
Chris |
#13 |
tarmac ripper
Thanks.
Tom signal ground (see the scheme) is not connect to anything so choke is not shorted. I elected to connect to earth the (-) lug of the first cap (that's is the input to the first choke) for safety reasons. Cerrem, not sure I got your idea properly ... Gianluca |
#14 |
What you have labeled signal ground is the 'real' ground. If you want to connect your chassis anywhere it should be there, otherwise your signal ground will be bouncing around relative to the chassis (earth.) You can make the connection to the chassis through a small value resistor; that's up to you. I've never found the resistor necessary unless there were other grounding problems like ground loops.
Where to connect the cathodes? Obviously to signal ground in any case. |
#15 |
tarmac ripper
OH! Thanks all! So I was given a wrong suggestion ... I was told to tie to ground the first cap and let the cathode (signal etc...) return to the "floating" end of the last choke/cap.
I'll do that... I just need to swap a wire. Gianluca (much happier now) |
#16 |
#17 | |
This is a common-mode filter. You'll not find a 10H (or whatever) common-mode choke unless you roll it yourself. |
| ripple issues | simonwai999 | Parts | 5 | 27th August 2008 04:24 AM |
| too much ripple | steevo | Solid State | 11 | 5th July 2007 07:27 PM |
| Plate chokes & Power chokes | JC951t | Tubes / Valves | 3 | 19th October 2006 03:18 PM |
| How much ripple on B+ is allowed? | Rundmaus | Tubes / Valves | 11 | 16th October 2005 02:19 AM |
| How much ripple?? | JDeV | Tubes / Valves | 23 | 2nd April 2003 11:05 PM |
| Page generated in 0.09171 seconds (76.28% PHP - 23.72% MySQL) with 10 queries |
