| diyAudio Sponsor | ||
#11 |
....that is what you have when you learn english from the films that our children are looking too oh well.... i admit i am ashamed and i am sorry.....so lets proceed quickly to the problem that is presented here
when you burn it - burn it good |
#12 |
I'm not bothered; I'm a crass ba$tard. I just think that some peoples wives check up on them to keep them in line...hence the languauge police to help prevent slaps and being forbiden to use the computer.
#13 |
#14 |
Given that your circuit is preceded by a volume control, I assume that the signal level is fairly healthy. Changing things in the reference chain of the CCS will only affect noise/hum, but you have enough signal not to need to worry.
If you had a smaller signal you might be worried. The LED is quiet but even if you manage to find the old low brightness LEDs, the internal resistance isn't all that low (5R or so) so you don't get particularly good attenuation of power supply hum from the potential divider formed by the LED's internal resistance and R2. Replacing R2 with a crude CCS (DN2540N5 plus two resistors) can help considerably.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#15 |
EC8010 - thanks .... the problem is to use those exotic parts like DN2540N5 and LND150.... i am living at the end of the galaxy (hm, well it is maybe the begginning actually
LED diodes that i have are from some not known type and i have tried to pair them so i have 2 pairs (4 pieces) - one that is brighter and the other that is not that bright.... i would like to avoid that problem by putting something better - not to have those LED's - that was the reason for the original question.... oh well - i might try to find something that is bright and red.....in fact i like their look in the preamplifier - everything is glowing all around....tubes LED's i might also use some capacitor to put in paralel with the LEDS - lets say >10uF......??!! opinions?
#16 |
OK, if you have trouble getting parts, then use an MJE340 as a crude CCS in place of R2. There's no need to fuss matching LEDs - and you don't want good ones! You want the cheapest nastiest oldest dimmest red LEDs you can find. The nice bright new ones have a much higher internal resistance...
There's no need to put a capacitor in parallel with the LED. Assume 5R internal resistance and that you want the capacitor's reactance at 100Hz to be equal to the LED's internal resistance. That's 330uF. It's hardly worth the trouble.
#17 |
oh yes - thank you......will do that .... thanks again
| Hitachi FET Substitution | poor_lackey | Solid State | 20 | 12th March 2011 01:15 AM |
| 6N1/6N3 substitution | woodturner-fran | Tubes / Valves | 7 | 31st January 2007 01:15 PM |
| E182CC substitution ? | bembel | Tubes / Valves | 5 | 11th November 2006 04:11 PM |
| 11k resistor substitution...? | mcelaj | Solid State | 3 | 6th January 2004 04:31 PM |
| Substitution MOS for Aleph 3 | Miles Teg | Pass Labs | 7 | 19th September 2001 04:59 PM |
| Page generated in 0.09285 seconds (73.94% PHP - 26.06% MySQL) with 11 queries |
