I would like to get a low-powered tube amp kit, and have narrowed my choices to these two well-known examples. Any opinions on their relative advantages/disadvantages sonically? I plan to use them with high-efficiency full-range speakers, or something along those lines, and currently have a Melos MA-111 pre-amp that would be nice to integrate (it's got a good phono stage). FWIW, I don't HAVE to use the Melos, but I'd like to if possible (it does seem to have a high output level).
Here are the respective blurbs: BOTTLEHEAD (pair monoblocks) "Single ended tube amp designed by Paul Joppa, at a price so low our competition can't figure how we do it - $549 for a pair of monoblocks with 3.5 watts of SE 2A3 articulation, resolution and sweetness." http://www.bottlehead.com/et/et.html DECWARE (stereo, bridgeable for mono) "The famous Zen Triode Amp model SE84C...a stereo single-ended triode amplifier with input level control. Uses SV83 output tubes. Still our hottest product! $499." http://www.decware.com/tubes.htm |
#2 |
diyAudio Senior Member
As you said FWIW my vote would go to the 2A3 design and both should work with your preamp anyway. My vote goes for that design for a number of reasons (nothing to do with the blurb I didn't bother to read) 1/Mr.Joppa knows what he's doing and I read a lot of his posts on the Joelist. 2/A 2A3 is a linear DHT that I prefer over the 300B on most occasions especially working full range. Just my
Frank |
#3 |
frugal-phile(tm)
A lot will depend on the speakers you plan to use. The Zen likes low impedance loads 2-6 ohms, the Paramour higher impedance...
You may find some comparisons on the Decware Forum but keep in mind the crowd there tends (but isn't necessarily) biased towards Decware product. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Based on what you guys are saying, and my own incliination toward monoblocks as opposed to all-in-one, it'll be the Paramour. My speaker plan (another project) would be a back-loaded horn based around the Fostex 168 Sigma "E" (6.5-inch FR). That one is plenty sensitive, it seems (94db) and is 8-ohms, and I'm not interested in research below-8-ohm options, since that's pretty standard (thought there's a thread on the Single-Driver site about a $2.38 auto speaker that has at least some kind of intrigued).
Thanks for the advice. |
#5 |
JLG
Do you have a set of plans for the cabinets? Cheers, Craig Ryder
Ryder Any fool can ask more questions than seven sages can answer. |
#6 |
My speaker plan (another project) would be a back-loaded horn based around the Fostex 168 Sigma "E" (6.5-inch FR). -------------------------------------------------------------------------------- These are tricky to get right (well the straight 168 Sigma was) and Godzilla and I have both been unimpressed with the final results of our backloading efforts with this unit. Worse still, a company in Australia was selling a horn based on these and got the closest thing to a bad review that the A-Licking Australian Hifi press has ever handed out. (And this from a mag who NEVER publish negative reviews). I think Cain and Cain are the only people who've actually reported a backload success with the 168 Sigma. Various iterations of ported and sealed cabs seem to have more success. Good luck though. Drew |
#7 | |
frugal-phile(tm)
The Q of the 168S is kinda high for a horn... the new banana cone 168ES has a bit better Q for horn loading... dave
#8 |
I'm going to be using the 168 Sigma (6.5", banana pulp), and as for the enclosure, I'm considering a few possibilities. I'd like to use a Tractrix contour, and to keep things simple would like to use published plans; then again, maybe I'll design them myself. Here are some of my ideas:
1. Something along the lines of the Hedlund horn -- which, as described on the web-- see links below-- appears to be made for an 8" speaker (the baffle hole is 19.2cm or 7.55 inches). Complex, and would require mods for my purposes, but intriguing. Plans: http://www.vt52.com/diy/diypage/hedlund/hedlund.html (click on the plans link for a .zip file containing complete diagrams in .pdf documents!). There are other approaches to the Hedlund, but this one uses mostly straight cuts (others use bendy plywood and are beyond my woodworking abilities -- see, e.g... http://www.homestead.com/sparkgap/Hedlund.html This guy is a master! His horns are beauties and check out his other stuff. He's got links to other pics of Hedlund variations. 2. The ML TQWT, i.e., the tapered-quarter-wave tube. His design is meant for the Fostex 164, a less expensive 6.5" Fostex driver than the 168 Sigma. It's cool-looking, but I'm not sure it's my style. Rationally or no, I kind of dig the back-horn approach just because of the design principles. The TQWT seems a bit dull. Plans: http://www.t-linespeakers.org/projects/martin/MLTQWT/ He's got a whole ton of stuff, include a 70-page paper on his project, plus updates and tweaks. 3. There is a Japanese site with heaps of plans, including two for the 168 Sigma series: 1. http://www2.nkansai.ne.jp/hotel/nakanou/bs-168.htm. This one is a ported box (boring). 2. http://www2.nkansai.ne.jp/hotel/nakanou/D-37.htm. This one is a back-loaded horn (cool). The main site is: http://www2.nkansai.ne.jp/hotel/nakanou/page12.htm |
#9 | ||
frugal-phile(tm)
dave
| diy preamps, bottlehead, decware.... | piwonka | Tubes / Valves | 3 | 3rd August 2008 02:27 AM |
| Bottlehead Paramour Iron/Cap Upgrade Kit | boonedog | Swap Meet | 1 | 27th April 2007 08:30 PM |
| dynakit decware bottlehead ... which to pick | lowtherdream | Tubes / Valves | 9 | 14th April 2007 03:43 AM |
| Decware SE84CS Zen triode amplifier for sale. | jim_vt | Swap Meet | 9 | 4th September 2005 11:57 PM |
| Starting my Bottlehead Paramour 2A3 build | Wardsweb | Tubes / Valves | 2 | 19th August 2003 10:42 PM |
