diyAudio Sponsor
Old 12th April 2006, 07:03 PM   #11
kevinkr's Avatar
A 10 ohm current sampling resistor in the cathodes of each output tube is a good idea.
Despite what has been said unless the screens are also operated from a regulated supply, regulating the -60V supply is not such a good idea as every small shift in B+ will result in an attendent shift in operating point. When both are unregulated variations in B+ will be somewhat offset by a similar offset in the bias voltage, while not perfect a lot of the op drift will be cancelled this way.
You can also regulate the B+ in which case you should also regulate the -60V supply.
Incidentally I believe this circuit has almost no headroom beyond what is required to drive the output tubes, and would recommend something like - 70V to -80V supply voltage. The positive supply does not have to be regulated, and with a CCS in the tail you could comfortably get away with about a 12V rail here.
Better still take a look at some of the all tube designs out there on the net. I have heard the AMC hybrid, and at least one home brew of a circuit very similar to this one, and it lacked many of the virtues of good tube sound. The output and power transformers are the biggest % of the cost and would not differ significantly if you choose an all tube design, or even designed one yourself. That pair of transistors could be replaced by a single 6SL7 or even 6SN7 if you wanted something really simple, and don't need lots of gain.
www.kta-hifi.net
Old 12th April 2006, 07:15 PM   #12
drago is offline drago  Hong Kong
For the CCS, do you mean this?
Old 12th April 2006, 08:35 PM   #13
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I'd echo everything kevinkr has said. Regulation could actually make the output stage's DC conditions less stable. A single transistor CCS isn't really up to snuff, a cascode would be better. Even then, there's precious little headroom and I see no virtues in this silicon drive.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
EL84 driven 2a3 alexg Tubes / Valves 3 30th June 2008 12:27 AM
G2-driven 6BM8 wfmali Tubes / Valves 34 13th February 2008 05:47 PM
g2 driven tubes gianis Tubes / Valves 10 24th January 2008 04:30 PM
How is a ESL driven directly by tubes? ak_47_boy Planars & Exotics 3 6th November 2006 07:44 PM
sub not being driven enough? dlagace Subwoofers 3 25th November 2003 11:26 PM
Page generated in 0.08051 seconds (74.06% PHP - 25.94% MySQL) with 11 queries
