Giaime's Preamp Finished!!!
Old 15th April 2006, 04:30 PM   #11
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
You know what?
Those photos were taken yesterday night at a friend's house, we were willing to try my preamp with his wonderful audio chain.
As soon as I flipped on the power switch, smoke come out of the power tranny
This morning I replaced the PT, it was a poorly done solder joint that shorted the B+ on the chassis
Old 15th April 2006, 05:32 PM   #12
poobah is offline poobah  United States
poobah's Avatar
Giaime,
Get some paper and tape... and then paint those capacitors!
Old 15th April 2006, 05:39 PM   #13
Giaime's Avatar
No no no I like them, they're pricey Nichicon!!!
Old 15th April 2006, 08:48 PM   #14
Makofoed-6sn7 is offline Makofoed-6sn7  Norway
Send a message via MSN to Makofoed-6sn7
Have you heard of something call'd fuse?
But serious, thats a very nice pre!
Still waiting for my funds to make mine. My SE amp with 6l6 ended up with a much simpler powersupply becouse I ran out of money.
The line under is true
The line above is false
Old 15th April 2006, 11:23 PM   #15
Giaime's Avatar
Fuse, amazingly, didn't blow. But I'm starting to think that 1A is a bit overrated
You're right, funds is the thing that block me. I have to study at the university...
if not, my preamp would have been:
- all octal
- all tube regulated
- 2 chassis (power supply and signal path)
Old 16th April 2006, 10:07 AM   #16
Hi Giaime,
Ah, you are also in the student group... Well, at least your a little higer up in the system. Its a couple years left before I'm going to the univeristy.
Forgot to mention a thing that I also do to protect my circuit and transformers. In preamplifiers and other equpitment that don't use much power or have large resistans in the powertransfomer, I usally put a small value resistor in series with the ht winding, if its center tap'd, one from each side from the tap, if not, one on each side of the winding. The value usally is from 4.7ohm-10ohm. low value for more power full transformer, 1watt metall reistors are fine. That trick saved me once. Only the reistors burn'd. But, of course, you need to solder clean and solid before the resistors...
Oh, sorry, that was mean, couldn't resist. Please forgive me.
Have a nice day!
Best regards,
Magnus Kofoed
Ps, 1 amp is way to much! I have a 250ma fuse in my power amplifer! I live were it is 230v. Double it if your living in a country with 110v.
Old 16th April 2006, 01:44 PM   #17
Giaime's Avatar
Thank you very much Magnus Kofoed for you reply.
I do live in a 220V country, and I must admit that 250mA fuse blows, but I'm using fast ones. I'll get some retarded ones and try. You're right, obviously. On more "expensive" project I'll fuse everything on the back panel (both mains and HV, and if it's an amp I'll fuse EACH output tube).
Money is not too much... I'm now listening to a 1.6W triode connected EL84SE. Sound is good, but frequency measurements show a not-so-hi-fi response...
Old 16th April 2006, 09:59 PM   #18
Haha! I must admit that your freq. response once and for all says that it is the ear that make the final desition. I always trust my ears.
My 6L6 amp has around 1-2w ouput, it is becouse of the opt. I wound them my self. But they are very good. Freq response was almost flat from about 35-23khz. Very little ringing too. But they are very, very ugly. I have no idea how much dist. my amp has, but for me it sounds good.
If you like I can always send you a pic and schematic.
Yes, that 250ma fuse must be slo-blo if it has solidstate rectifier. In my 6l6 that has a toob rectifier I use 250ma fast.
Maybe we should make our one: "We demand a free world!" club?
Best regards,
Magnus
Old 16th April 2006, 10:31 PM   #19
Giaime's Avatar
I've been told that if the annoying buzz of my preamp suddenly disappears when disconnecting the power cord, it doesn't depend on wiring / grounding issues. So it's pickup from the transformers... I have to better decouple them from the chassis, at least mechanically.
Old 17th May 2006, 07:36 PM   #20
Giaime's Avatar
Hello there, sorry for forgotting about this thread.
I've since resolved all humming problems, they were caused by bad grounding.
I've made a page on my site to suggest some possible Plate Follower tube candidates, since I recived some feedback from some people who built the PF as a standalone linestage, with very good results.
Here it is, please feel free to make suggestions!
http://www.giaime.altervista.org/plate_follower.html
Giaime's Preamp Finished!!!Hide this!Advertise here!
finished my PCC88 preamp Roemhild Tubes / Valves 12 18th January 2012 08:04 AM
Preamp finished but it wont play.. XXLPeanut Solid State 19 12th June 2006 06:37 PM
Giaime's new toy - aka the UniOctal Giaime Tubes / Valves 91 3rd June 2006 05:17 PM
Giaime's last nightmare - aka RIAA faceoff Giaime Tubes / Valves 32 8th January 2006 05:38 AM
Just finished my first tubes-preamp Ralph Tubes / Valves 7 26th April 2002 09:26 AM
