| diyAudio Sponsor | ||
Anyone ever try them in SE ?
Ive been thinking of it. maybe parallel one 6080 per channel.. I kind of want to run them around 300v so I dont need an OPT with too heavy of a primary.. but i cant find graphs that go above 250v.. ah.. ill think of something. I suppose I could always make a OTL. |
#2 |
diyAudio Senior Member
Hi Clot45,
Unfortunately I can't provide graphs at that high plate voltages either. The tubes should get more linear and short of finding someone with a sofia or a plotter I can only give a diagram (not mine) for inspiration: Cherio,
Frank |
#3 |
Are these really the best tubes to use in a SET? They're not exactly linear.
Cheers |
#4 | |
I'll probably just end up OTL-izing them. |
#5 | |
Cherio, P.S.Sorry Brett.
Frank |
#6 |
I threw together this mono one really quick.
i guess 16ohm+ output. too tired to pick values for the resistors on the gain and cathodyne right now. I suppose i should have feedback too.. I got 2 big power transistors.. 500v 10a NPN.. can i get a bias supply with it?? im not too hot with SS. i guess i need.. what.. 0-80v, and 0 to -80v. off a ±120v supply. I should probably just buy some higher wattage pots.. |
#7 | |
Hi Colt45,
Any reason why you stack the tubes at the output stage like that? When you look at the signal's phase at the output you will see that it will result in a near cancellation. Unless of course I'm missing something. Quote:
After full wave rectification you'll still have ~90V left which should be more than ample. Cheers,
Frank |
#8 |
I better bump the B+ on the gain and cathodyne... or I wont get enough drive.
thats the "enhanced futterman" or whatever you call it.. except it normally uses a split supply (±60v, ±90v, whatever) using positive on top, negative on the bottom.. and no output cap. If I can figure out some kind of regulation then perhaps i should do split supply. |
#9 | ||
And why you want to cross your output of the splitter is beyond me too. See what I said above already. Quote:
Seriously,if you want this to work you can use a Futterman as a basis,he put in some clever tricks but you don't need those in DIY. While you're at it why not improve it in the process? Cheers,
Frank |
| Simplest 6080 or 6AS7 OTL Project? | Michael Rothacher | Tubes / Valves | 29 | 26th August 2010 09:05 PM |
| 6as7/6080 Se Otl | desperateaudio | Tubes / Valves | 103 | 6th January 2009 02:19 PM |
| WANTED - 6080/6AS7 Based Amplifier | baileyler | Swap Meet | 1 | 26th March 2008 11:17 PM |
| Transformer coupled 6AS7/6080 | dsavitsk | Tubes / Valves | 48 | 20th September 2007 07:16 AM |
| Set 6080/6as7 | needtubes | Tubes / Valves | 34 | 28th August 2004 05:40 AM |
| Page generated in 0.10611 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
