diyAudio Sponsor
Old 6th April 2006, 08:32 PM   #1
tenderland's Avatar
Default % error for primary resistance
Hello I just recieved my output xformers and checked out the dc resistance . the secoundary are identical . The primary , one is 39 ohms
the other is 47. The spec sheet indicates 40. This is a 17% error , is this acceptable ?
thanks
J
"If every one is making wheels , why make wheels ? " Steve Jobs
Old 6th April 2006, 08:48 PM   #2
Brian Donaldson's Avatar
I think not I would expect 5% tollerance, but 10% would be acceptable
Old 6th April 2006, 08:51 PM   #3
SY's Avatar
That's not terribly unusual. For less exotic winding geometries, the outer windings will have the same number of turns as the inner windings, but because they're farther from the center, the length of each turn is longer so the resistance is higher. You'll also see a bit higher leakage inductance from the outer layer, which is why you'll sometimes see compensation caps that are not symmetric side-to-side.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 6th April 2006, 09:02 PM   #4
tenderland's Avatar
Default xformer
These are Plitron pat -3025 very expensive torodial output xformers , I would think they would be closer
so more exotic windings like toroidal should have less of an error?
Old 6th April 2006, 10:25 PM   #5
tenderland's Avatar
Default problem solved
Good thing im anal and measured the resistence , it seems they shipped one correct xformer 3025 and one incorrect 3035, the box was correct though.
Marantz CD63 KI SIG, Error 12, Sled Error problem sisik Digital Source 1 9th November 2008 03:12 PM
Thermistor B+ or primary mashaffer Tubes / Valves 9 28th August 2008 09:07 AM
Need UTC PVM-3 primary ? PTSOUNDLAB Tubes / Valves 4 6th May 2005 04:54 PM
switchable 2.5k/5k primary ot drembo Tubes / Valves 1 16th March 2004 06:07 PM
Whats worse, 1db error in response curve or a phase error of 6? primalsea Multi-Way 5 13th May 2003 01:24 AM
Page generated in 0.08461 seconds (70.09% PHP - 29.91% MySQL) with 10 queries
