| diyAudio Sponsor | ||
I decided to try testing a cheap 70.7v line transformer on the impedance analyzer at work. The graph represents the primary impedance with a 10 ohm resistor load on the secondary. The X axis is frequency and the Y axis is impedance. The inductance was not very high, around 5-6 henry. Anyhow heres the results.
#2 |
If I've done my sums correctly, the leakage inductance is around 22mH. I'd say this impedance analyser might be quite useful for comparing output transformers.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Testing the transformer for the first time | Tripmaster | Chip Amps | 21 | 6th May 2008 04:22 PM |
| transformer testing via DM? | spirus | Parts | 3 | 22nd July 2005 06:00 PM |
| Transformer Testing | SteveS | Solid State | 3 | 6th March 2002 11:53 PM |
| Testing transformer output | DieterD | Solid State | 12 | 9th January 2002 01:45 PM |
| Page generated in 0.07251 seconds (65.26% PHP - 34.74% MySQL) with 11 queries |
