| diyAudio Sponsor | ||
Hello
As You all know, am I looking for a 20W SE amplifier. Some have told me a EL509 in enhanced triode mode is the amplifier with a fine sound. I found the SYNOLA 509 ( based on a EAR 859 ) but only 10 watt. My question is: I set the DC current to 90 mA/EL509 OPT with RA at 1k8 - 2k. Separate bias pot meter. Can the driver tube drive 2 EL509 tubes? Benny |
#2 | ||
Hi Benny,
With the considerably smaller EL36 used with screen drive, I measured up to 20mA peak screen currents for comparable audio load situations already, see here. I bet the driver is already at the edge feeding one EL509 screen grid, not to talk of two. If you want to feed two screen grids this way, at least use something in the range of trioded EL84 or EL83 instead. Nota bene, have a look at this one, too. But don´t trust the EL509 screen drive curves shown there. I don´t know what he is showing there, but for lower plate voltages it has nothing to do with the reality of about half a dozen of EL509/PL509 from 3 different makers (and construction) I measured myself. The curves looked all as gross as the screen driven EL36 shown above. Tom
If in doubt, just measure. |
#3 |
ESCUSE-ME:
Me gusta este esquema de amplificador , pero yo por mi parte tambien necesito mas potencia de salida. Lo ideal segun informacion de USA. de Petersen & Sinclair, es que un amplificador para uso domestico a tubes, necesita de 15 a 20 watts. Pienso que con unpar de EL.509 en paralelo, se pueden obtener los 15 a 20 watts. de audiio. Tambien debo decir que nunca he probado de construir un amplificador SE. con estos tipos de circuito. Me gustaria poder realizarlo con su ayuda. Gracias. Espero su respuesta por correo. The ingles it is very dificult for me. Sorry. |
#4 |
Google Translate of your post: I like this scheme amplifier, but I for one also needs more power output. Ideally, according to information from USA. Petersen & Sinclair, is an amplifier for home use with tubes, you need 15 to 20 watts. I think with EL.509 unpar of parallel, you can get 15 to 20 watts. of AUDiiO. I should also say I've never tried to build a SE amplifier. with these types of circuit. I wish I could do with your help. Thanks. I await your response by mail.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| EL509 as a CF | GK | Tubes / Valves | 1 | 9th May 2008 09:25 AM |
| el509/519 | horn150 | Swap Meet | 2 | 20th September 2007 08:48 PM |
| EL509 vs EL519 | resident | Tubes / Valves | 3 | 15th November 2004 02:01 PM |
| EL509 Alternatives for this amp | cadman | Tubes / Valves | 26 | 19th September 2003 12:40 AM |
| SE amp with EL509/6KG6A (help) | NotInTheMafia | Tubes / Valves | 1 | 10th December 2002 07:51 PM |
| Page generated in 0.08998 seconds (73.54% PHP - 26.46% MySQL) with 11 queries |
