Old audio amp change
Old 5th April 2006, 12:25 PM   #1
24kilo is offline 24kilo  United States
Default Old audio amp change
I have a old Olympic 812, ( which I was given the scmat's to, Thank you) I want to change the rectifier with Diodes, Of course I need a dropping Resistor. But if you look at the circuit the plat Voltage on the 12ax7 is only 65 and the 50c5 is 145-150. Will the extra %20 Hurt me?
Old 5th April 2006, 12:51 PM   #2
On Hiatus
SY's Avatar
I'm not sure I understand the question. Are you replacing the half-wave recitifier with a full-wave bridge?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th April 2006, 01:53 PM   #3
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
I would change to a full-wave bridge and if necessary, increase the cathode resistor for the output tubes. Less hum, and transformer will run cooler. Extra voltage won't be a problem as long as the output tube dissipation is kept within ratings.
50C5 is rated for 5.5W, IIRC. If cathode resistor is 100 Ohms, then cathode voltage / 100 is cathode curerent. Say 8V: 80 mA. 150V * 80 mA, is 12W, too much. So increase cathode resistor and measure again.
Old 5th April 2006, 09:00 PM   #4
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The first time I read this I thought, what the schematic already shows a diode. Then my brain rewound about 50 years and I remembered the selenium rectifier. In most cases you can just replace these with a 1N4007 and gain about 10 extra volts. Check to make sure that you are not running too close to the maximum ratings on the electrolytic caps. They might need replacing also. If so use capacitors with the same value (microfarads) and the next higher voltage rating. The tubes will probably be OK. You are already getting more voltage since todays line voltage is higher than it was 50 years ago. The cathode resistors on the 50C5's could be changed to the next higher value if the tubes start to glow red.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old audio amp changeHide this!Advertise here!
Advice sought on voltage change to a PS Audio Trio A-100 (Icepower 200ASC) pcavelle Class D 0 2nd November 2007 01:09 PM
name change Juergen Knoop Forum Problems 2 25th October 2007 08:50 AM
Audio, cables, and the ear-new science-the rules change KBK Everything Else 4 23rd October 2007 01:46 AM
Mic mod for audio testing (change FET?) effect Multi-Way 7 24th January 2004 07:39 AM
qts change Ilianh Multi-Way 3 30th November 2002 09:26 PM
