Need 45 tubes
Need 45 tubes
Old 5th April 2006, 11:56 AM   #1
Burnedfingers is offline Burnedfingers  United States
Default Need 45 tubes
Is anyone making the 45 tube anymore? Can I sub 2A3's in place of 2) 45's?
Old 5th April 2006, 12:41 PM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Emission Labs EML45 is current production but really expensive. Is it difficult to source 45 in the U.S. now? We had a shipment of about two dozen 45s last year from te U.S.
You can put in a 2A3 in a 45 circuit. The difference will be higher B+ (250V vs. 275V), lower current (50mA vs 35mA), and load (2.5K vs 5K). My Sovtek never complained.
Old 5th April 2006, 05:26 PM   #3
kevinkr's Avatar
Need 45 tubes
Late ST envelope type 45's can be had on eBay for relatively reasonable money. There are several companies that make the 45 currently, TJ, EML and AVVT come to mind - unfortunately these are well over $250/pr and depending on brand can be much more than this.
The 2A3 with changes previously mentioned will work, but it is a different tube, and sounds quite different. I recommend that if you want a 45 amplifier you buy good NOS or used 45's.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th April 2006, 06:15 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Need 45 tubes
Hi Joe,
This is for repair on your old radio's? They are darn expensive. I would not design anything new with 45's just due to that.
I bought a few for my old sets. I refuse to pay the nutty prices for new manufacture or some of the NOS guys either. It really hurt to lay that much money down.
-Chris
Old 5th April 2006, 07:45 PM   #5
vt_229 is offline vt_229  United States
Default 45s
The 46 will work as a good sub if you tie the grid 2 to the plate. it uses the 5pin socket so this is NOT a drop in. I have done this one several old amps for guys that want to use them, and were not concerined with altering the OEM set up. For a little more info on the 46/45 switch as well as using 2a3 in the same amp check out this web page http://www.the-planet.org/Ragtop.html
Old 5th April 2006, 09:45 PM   #6
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Keep in mind that a 2A3 draws 2.5 amps of filament current. This may make your filament transformer unhappy.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 5th April 2006, 10:24 PM   #7
This is for an Atwater Kent Radio so I would like to keep it as close to stock as I can.
Old 6th April 2006, 12:24 AM   #8
Atwater Kent, nice piece of audio gear
FWIW, I got some Globe Cunningham 245 from my friend for about $75 each. Don't know where in the US he sourced them though.
Old 6th April 2006, 04:33 PM   #9
Default 45s
Good find, with an AK changes like a 46 would be disastrous to the value and a darn shame. Hope they sound good thatís a fair price as long as they have a lot of life in them, NOS?
Old 6th April 2006, 08:12 PM   #10
anatech's Avatar
Need 45 tubes
That's what I had to buy mine for. I think it's a 60C.
-Chris
Need 45 tubesHide this!Advertise here!
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 10:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 01:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 07:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 12:26 PM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 10:22 AM
Copyright ©1999-2017 diyAudio
