SE 20W. What tube?
SE 20W. What tube?
Old 3rd April 2006, 09:21 AM   #1
Hojvaelde is offline Hojvaelde  Denmark
Default SE 20W. What tube?
Hello
One of my friends arsked me to build a amplifier.
He wanted 20 watt and SE. Two monobloks. Separate PSU.
I think 20 watt is OK because in the moment he is using a 22 watt PP amplifier he has borrowd and the room is +25 sqrm.
BUT 20 watts SE is not easy and he want a good sound.
I think the OPT must be Lundahls and the capasitores Jensen but what schematic/tube type can You recommend.
PSE KT88 can do 20 watt, but other excotics type as 211, 811, 813, 845, SV572 or 6C33 can also do 20 watt.
Help ( experience ) wanted.
If it sound well I think I will build two to my self to :-)
Benny
Old 3rd April 2006, 03:57 PM   #2
blacklight is offline blacklight  Finland
Seriously, that's a LOT of power for such a small room especially if the speakers are fairly efficient. Anyhow, you might want to take a look at KR tubes. They claim 22W class A for the 842VHD model and even 20-24W for their 300B models. Not cheap though (~500€/pair). And of course, you need lots of voltage.
Old 3rd April 2006, 04:23 PM   #3
Alain Dupont is offline Alain Dupont  France
Alain Dupont's Avatar
Hojvaelde,
>> 20 watt and SE
Wouahhh > 20 watt and SE ; is this first condition highly important ? Or 18 watts
could do it?
For SE its douable with 2 * 6C33C-B ==> 32/36 watts
with 1 tube it's only 16/18 watts max {}
see schematics from Ari Polisois: http://www.valvediy.com/simplexpg1.html
{I am building the Simplex } Ari published last year a SE with a triplet
of 6C33C-B for 45 watts on AudioXpress.
http://www.jogis-roehrenbude.de/Lese...schreibung.htm
>30 watts the problem is a custom OPT, price will be high.
SE with 300B:
AUDIO NOTE CONQUEST 18W Classe A with 2 * 300B in //
SE with 211 tube
ONGAKU Audio Note Single Ended classe A 25 with 211 tubes
{> 850 volts ; it's the Best! in all classes!}
Push-Pull: Attention here you get power but loose the flower of second harmonic distortion for 3rd harmonic distortion and negative feedback...
On the Push-Pull side 6C33C-B at 70 watts
See the articles by Menno at plitron:
http://www.plitron.com/PDF/PB/specs/pat4144-00.pdf
For the 300B Push-pull at 30 watts
Push-Pull: http://www.plitron.com/PDF/PB/specs/pat4150-00.pdf
EL34 Push-pull at 25 watts
http://www.plitron.com/PDF/PB/specs/pat4148-00.pdf
It's my own view for SE ; perhaps someone can lead to other choices.
Alain.
Old 3rd April 2006, 04:36 PM   #4
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
813 in SE ultra linear is easy to drive and simple PSU. You would end up with an amp like a SE 6BQ5/EL84 with lot's of power (25 watts easy). I am awaiting output xfmers from Handwave for this proposed experiment myself. For the past two years waiting!
There is a Euro version of the 813 without a plate cap. I forget the number. Use that one.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 3rd April 2006, 05:22 PM   #5
Sylvania is offline Sylvania
Hi Benny
Look at my homepage www.micro-io.dk. I have used the 6c33 and i get 36Watt from them with homemade transformers.
Best regards Kim Olesen
PS: du kan finde mit telefon nummer på krak (se under feedback på min hjemmeside) hvis du vil vide mere.
Old 3rd April 2006, 06:10 PM   #6
edl is offline edl  Hungary
edl's Avatar
An 5-10W SE amp relatively will be as loud as a 20W PP amp.
I would build parallell-SE EL84. That gives 10W. And EL84 sounds as nice as the gold-priced "super-audiophile" DHT-triodes. Anyway the quality of the amp depends more on the output transformer, PSU, driving. The type of the output tube isn't the first.
Or you could try 6L6GC, KT88, EL34, 807 etc... These are popular, cheaper, but also good-sounding tubes.
Old 3rd April 2006, 06:14 PM   #7
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
I would do PP
Seriously, 807 PSE sounds VERY good. So does KT90, talking about unusual tubes. Or, if you can find any, EL156
Also medium-small transmitting triodes sound good. A normal 845 SE is pretty straightforward, iron is everywhere and you'll get 20W without stressing the tubes.
However, given the price of China 845 (which sound good), I would go A2 aka Powerdrive (www.tubelab.com) and get the full 40W.
Maybe you could scale down it and use 300B instead
Old 3rd April 2006, 08:00 PM   #8
rcavictim's Avatar
Default Re: SE 20W. What tube?
Before this thread drifts into a discussion about the merrits of SS versus tube amplification let me remind some that the original poster has asked a direct question. The question, as I read it, is about single ended options to produce 20 watts RMS because a friend already experiencing 22 watts push-pull has requested Single Ended.
Originally posted by Hojvaelde
Hello
Benny
Earlier I offered a SE penode 813 as an option because it is S I M P L E to implement and I'm told sounds good.
As further contribution I can suggest that 6080's in parallel A1 ultrafeed and paracoupled can sound mighty good and can be set up without paying full fare for an expensive outoput xfmer like a Lundal. I am slowly working on just such a 20+ watt design on the bench now which employs four bottles per channel (8 triodes in parallel) and it sounds fabulous although only the output stage has been prototyped so far.
I also question that the caps "must" be Jensen. There are very top sound quality caps available that do not carry boutique names, and therefore are not burdened with boutique prices.
Old 3rd April 2006, 08:37 PM   #9
Fuling is offline Fuling  Sweden
A single PL519 will deliver 15-16 good sounding watts if you drive it by the screen grid.
B+ only needs to be around 400-450V
Old 3rd April 2006, 08:41 PM   #10
agent.5 is offline agent.5  United States
i am currently building one with eimac 250tl
also you may consider using gm70 tube and take a look at the site gm70
http://groups.yahoo.com/group/GM70/
SE 20W. What tube?Hide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 05:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 07:47 AM
