SMPS & tube pre-amp development board.
Old 2nd April 2006, 06:24 PM   #1
ianl is offline ianl  Netherlands
Default SMPS & tube pre-amp development board.
I posted pictures, circuit, and schematic for my first attempt at a SMPS/tube preamp at instructables:
LINK
http://www.instructables.com/ex/i/D4...5001143E7E506/
Thanks to everyone who answered my questions about switching the tube heater.
Ian
Old 10th April 2006, 04:42 PM   #2
nickds1 is offline nickds1  England
nickds1's Avatar
I'm slightly puzzled as to why you use a PIC & FET driver to make an SMPS when there are several appropriate single chip specialist SMPS devices around that give you all sorts of stuff, such as very high performance (I get approx 88% efficiency), current limiting, HV shutoff etc. for very very little cost. The EMI/RFI is also easy to control - I use a variety of HP & Tek test kit to check my amps' performance, and removing SMPS artifacts (however you make the SMPS) is non-trivial, but can be done by using high switching frequencies, and careful control of artifacts on the supply rails, using shielded inductors and management of the grond plane.
For small tube/valve projects, my preferred chip is a MAX1771:
MAX1771 Nixie/Valve PSU.
The above link was originally done as a Nixie PSU a few years back but is widely used by valve/tube radio enthusiasts as a battery eliminator - I didn't use the Maxim app note as it didn't actually save any chips or components, as to drive the FET properly you need a specialist driver device - a PIC or an AVR doesn't have I/O ports that are "stiff" enough to get decent efficiency directly driving a FET, and there are capacitively induced currents in the FET gate that can & will damage the MCU's I/O ports. This is why LT,Maxim et al make specialist SMPS chips...
Its easy to make an SMPS, but getting one to do the best possible job is tricky.
Nicko
"The whole plan hinged upon the natural curiosity of potatoes" - S. Lem
Old 10th April 2006, 06:05 PM   #3
I use the TC4427a fet driver from microchip.
Also: switching at higher frequencies is not always so straight forward. The coil charge and discharge time can be calculated. Frequencies beyond these limits don't use the coil to its fullest. Slower frequencies burn energy in the coil or fet. There is a "best frequency" for a given coil. The pic calculates this based on coil size and supply voltage. I have worked with the 1771 in the past. I just really lke having software control and not being locked into a certain vendor.
SMPS & tube pre-amp development board.Hide this!Advertise here!
SMPS for tube amp? kubeek Tubes / Valves 17 23rd August 2016 08:39 PM
Car audio LM3886 + SMPS on single sided board rwaudio Chip Amps 43 20th February 2015 02:12 PM
Smps In Development albert_emule Power Supplies 3 11th April 2009 10:29 PM
DSP development board suggestions starn02 Digital Source 0 14th April 2006 07:06 AM
Development board Atmel ATmega Freddie Everything Else 1 16th August 2003 03:27 PM
Copyright ©1999-2017 diyAudio
