| diyAudio Sponsor | ||
#21 |
Hi rdf,
those plate curves actually look quite good Did you watch g2 dissipation? If it stays within reason, and you donīt want to trace higher plate voltages out of safety reasons, try to do a reasonable extrapolation at least, so actual plate voltage swing at an inductor (OPT primary) would be covered. Tom
If in doubt, just measure. |
#22 |
Hi Tom. The 814 is apparently part of the same family as 813, with lower ratings. From the strong similarity in pentode curves I had high hopes. Maximum screen voltage varies by spec sheet, one says 300 VDC, another 400 VDC. That's why the curves end soon. 900 VDC with a 560 ohm screen protection resistor showed nothing to cause alarm though, no funny glows.
Good point about the screen dissipation. I should have monitored current as well. However with my 5k, 500 VDC rated SE OPT the best I could achieve as a tremendous sounding, hideously inefficient 2 watts. With a pair of 813's and a box of 828's (hint, hint) waiting their turn I decided to leave the 814 aside for now. So many tubes, so little time!
Ears aren't microphones. |
#23 | |
#24 |
Has anyone traced out any of the new Mullard & Tung-Sol re-issues and plotted them against the specs of the originals? Just curious-- that's one experiment I would LOVE to see.
Heghlu'meH QaQ jajvam! |
| Computing or measuring anode curves w/ CFB | Tubes4e4 | Tubes / Valves | 3 | 19th May 2009 10:31 PM |
| Derive Triode Curves from Pentode Curves? | dsavitsk | Tubes / Valves | 3 | 14th May 2007 06:10 PM |
| Wanted Triode strapped curves for pentode of ECL82. | Shoog | Tubes / Valves | 2 | 28th March 2007 08:03 PM |
| EL34 triode-connected grounding-grid curves? | mcshaggy | Tubes / Valves | 0 | 27th March 2007 03:18 AM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 12:36 AM |
| Page generated in 0.07139 seconds (73.78% PHP - 26.22% MySQL) with 11 queries |
