diyAudio Sponsor
Old 31st March 2006, 07:36 PM   #1
vixr is offline vixr  United States
vixr's Avatar
Send a message via AIM to vixr
Default equivilent part numbers for 6K35HF
does anyone know if hammond sells a transformer with the same spec as the Allied 6K35HF???
sorry about my wallet...
Old 31st March 2006, 10:11 PM   #2
Alain Dupont's Avatar
vixr,
There are 2 similar models at hammond
* 166K6 6.3 VCT at 1.2 Amps Primary 117 volts
and * 226E6
but they are at 25 and 34 cad$ each so buy the Allied 6K35HF
at 7.44 U$ it's cheaper !!!
Alain.
Old 1st April 2006, 03:17 AM   #3
vixr's Avatar
Wow... That's pretty expensive... I was trying to save a few bucks on shipping by buying both transformers from the same vendor. The 269AX is in the 35 dollar range too...Thanks for the info.
Kenwood kac-x201 (part numbers) SomeDude Car Audio 9 20th October 2007 01:17 AM
Can I get a few part numbers for Pots? Destroyer OS. Parts 5 19th January 2006 09:20 AM
transistor part numbers bjr Parts 2 4th September 2005 05:26 PM
SMD part numbers? nuppe Parts 0 15th December 2004 11:04 PM
help needed to confirm part numbers chipco3434 Chip Amps 6 15th August 2004 01:05 PM
Page generated in 0.08125 seconds (66.66% PHP - 33.34% MySQL) with 10 queries
