diyAudio Sponsor
Old 27th October 2009, 08:56 AM   #171
Shoog's Avatar
You need 200V caps for the output. You can probably get down to some value as low as 470uf each cap.
On the input you need 400V.
I have always used dead Switch Mode Power supplies for cap sourcing - they usually have a pair of 250V or 400V caps hidden away.
Shoog
Old 27th October 2009, 04:01 PM   #172
Another great tip Shoog - I found a MOT on EBAY - $13 each and a $1 light ballast. Better start thinking about the chassis
Old 19th November 2009, 10:46 PM   #173
I am currently working up to building a second version of this amp ... I anticipate this version to have better high frequency extension and tighter bass. I will lash up a schematic in the next few days and post it up for consideration.
Shoog -- I would be very interested to see this - if possible would like to see the PS section as well including the pwer source for the 6as7 CCS. Now I am thinking to build a hifi of this first and then perhaps later a bass amp. thx.
Tube Preamp Idea mattthegamer463 Tubes / Valves 14 8th February 2009 12:56 AM
Footswitch Idea for Tube Amp blindsjc Instruments and Amps 0 5th June 2008 04:29 PM
CCS current sink in the output of my 2 tube 6080 amp. Shoog Tubes / Valves 35 9th July 2006 02:15 PM
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 1 27th May 2006 03:41 PM
Page generated in 0.06517 seconds (82.32% PHP - 17.68% MySQL) with 11 queries
