| diyAudio Sponsor | ||
Just bought a Olympic SA-812, I can't find anything on it. It has one 12AX7 and two 50C5's. I just changed the caps and it sounds great...But I want to use it for my Guitar amp and would like the Schmatics so I can mod the front end for overdrive. Any Help? Or can you tell me how this tube Config is laid out? BTW here's a pic
http://i21.ebayimg.com/05/i/06/85/65/c2_1_b.JPG |
#2 |
Based on the word "Stereo" on the front panel, I'm going to guess that there are 2 single ended channels using a 12AX7 section driver and a 50C5 "final".
The 50C5 data sheet suggests that the amp uses a series heater string and doesn't have a power transformer. That's both cheap and DANGEROUS. Perhaps the best thing to do with that unit is canabalize the O/P "iron". Turning it into a safe guitar amp is probably not in the cards.
Eli D. |
#3 |
I should have said, Sorry it's Mono. It says Stereo but it mono. The Speakers are inside. I've already grounded the chassis and no more floating ground.
#4 |
OK, I have good news... and more good news.
First, I'm holding the schematic in my hand - a scan will cost you an email... Second, it actually has an isolation transformer in it (assuming it's the same as the SA-813 and 814...) so it's somewhat safe... ...and some bad news - you'll need another tube to get enough gain for a guitar - maybe add a 12AV6 or 12AU6? tbavis(at)rochester(dot)rr(dot)com |
| OT for audio but still tube | Andrewbee | Tubes / Valves | 1 | 12th August 2008 05:29 PM |
| A new audio tube | HollowState | Tubes / Valves | 50 | 23rd December 2006 06:41 PM |
| car audio tube amp answer??? | DJNUBZ | Car Audio | 0 | 21st January 2006 05:07 AM |
| Page generated in 0.10205 seconds (77.76% PHP - 22.24% MySQL) with 10 queries |
