diyAudio Sponsor
Old 29th March 2006, 06:50 PM   #11
With all due respect, all CD players @ 0dBFS have 1 Vrms output not 2!
Old 29th March 2006, 06:57 PM   #12
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I think you'll find it's 2V. I don't have the "Red Book" standard, but that's the accepted figure and I've measured a number of players that corroborated that number.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th March 2006, 06:57 PM   #13
SY's Avatar
Checking three at random, I find:
Quad 99- 2.4VRMS
Cyrus - 2.1V
Ayre CS-7 - 2.25V
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th March 2006, 07:00 PM   #14
EC8010's Avatar
Oh yes, we shouldn't forget the players that were designed to sound better in AB tests by virtue of being louder.
Old 29th March 2006, 08:48 PM   #15
Miles Prower's Avatar
Default Re: What Design to Use?
Originally posted by Jason Watts
Which of the three designs listed below should produce the best performance. What would be the preferred design?
It depends...
1. Common-cathode stage, fully-bypassed cathode:
Highest voltage gain, highest THD, and lowest possible input Vp-p.
2. Common-cathode stage, unbypassed cathode:
Trades off voltage gain for improved THD, and more input Vp-p.
3. Single-stage inverting feedback amplifier:
Trades off lots of voltage gain for very low gains and enhanced distortion performance. Most often used as a "plate follower" to invert a signal at or close to unity gain. (Cathode followers produce an in phase signal at close to unity gain.
As for your situation, what do you need so far as voltage gain, distortion performance, input Vp-p? Decide that, and you have your answer.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 29th March 2006, 10:08 PM   #16
lndm is offline lndm  Australia
Default Re: Lets Try This Again
And then there's the swamped common cathode stage (partially bypassed). Using an unbypassed cathode resistance of 1/gm, on its own or in combo with some bypassed resistance or an LED, will linearise the transfer curve.
About Zo, it should be low compared to the load, generally speaking.
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.07817 seconds (77.30% PHP - 22.70% MySQL) with 10 queries
