What Design to Use?
What Design to Use?
Old 29th March 2006, 03:36 PM   #1
jwatts is offline jwatts  United States
Default What Design to Use?
Which of the three designs listed below should produce the best performance. What would be the preferred design?
1. Common-cathode stage, fully-bypassed cathode:
2. Common-cathode stage, unbypassed cathode:
3. Single-stage inverting feedback amplifier:
See the link below.
http://www.aikenamps.com/Equations.htm
Old 29th March 2006, 04:17 PM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
What Design to Use?
Default Re: What Design to Use?
See the link below.
Even a newbie like me knows you can't just compare tube stages on a philosophical basis like that. What is the application? What is the gain and output impedance required? What surrounds that stage, active loading, passive loading, regulation, etc.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 29th March 2006, 04:39 PM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Which is the preferred method of breaking open atoms?
1 A hammer, fully shrouded rubber handle:
2. A laser, paid for by somebody else:
3. A star, not paid for, but quite a long way away:
As a physicist, you owe it to yourself to frame questions better.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th March 2006, 04:52 PM   #4
EZ_Angus is offline EZ_Angus  Scotland
Oooh Oooh, I know this one, its the hammer, innit??
"Give me the Luxuries of life & I will gladly live without the Necessities" (Frank Lloyd Wright)
Old 29th March 2006, 05:32 PM   #5
Default Question
A neutron is the preferred way to split an atom. By the way I get paid to prevent neutrons from splitting atoms. Itís a great job if you like high stress and high liability one calculation screw up and large quantities of atoms get split. Very ugly. I am sorry for asking such a vague question. My intent was to eliminate the need to do a large quality of research and rapidly eliminate a few of the possibilities. I will be more specific next time.
Old 29th March 2006, 05:56 PM   #6
EC8010's Avatar
Not to worry. Having avoided splitting atoms, what did you want to do with your gain stage?
Old 29th March 2006, 06:20 PM   #7
Default Lets Try This Again
What are they advantages and disadvantages between a fully-bypassed and unbypassed cathode? What is the typical input impedance of an off the shelf tuner or CD player? What is a nominal voltage gain typical desired during amplifier construction? Why are they two different outputs for the unbypassed cathode amplifier? Should I try to design the amplifier such that the output impedance is equivalent to my driver impedance?
Old 29th March 2006, 06:23 PM   #8
leadbelly's Avatar
What Design to Use?
Default Re: Lets Try This Again
You're still missing our point. You've told us what comes before, tuner or CD, but what comes after
Old 29th March 2006, 07:14 PM   #9
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Avoid splitting ears! Sorry I just couldn't help it.
The answer to the question obviously depends on the application, which determines the required amount of gain. Once this is known then some choices can be made.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 29th March 2006, 07:37 PM   #10
EC8010's Avatar
With your avatar?
Back on-topic: In the absence of anything else, I'll make some sweeping assumptions, pronounce a few edicts, then go to bed before the fur flies.
A standard CD player produces a maximum output of 2VRMS. That's quite a handy sensitivity for a power amplifier. Ergo, all power amplifiers should have a sensitivity of 2VRMS for full power. Oh, there are other sources? All digital sources tend to produce 2VRMS. Analogue? What do you mean, analogue? LP? Make the RIAA stage produce 2VRMS. Tape? I'm biased against the stuff. FM tuner? In the unlikely event of you having an FM station that doesn't hammer the Optimod multiband compressor, its future is short-lived and obsolescence beckons (dastardly digits).
Well, that made everything easy. All you need for a pre-amplifier is unity gain. Have a look at SYs Heretical stage.
I'll run away now.
What Design to Use?Hide this!Advertise here!
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 06:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 03:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 03:56 PM
